weird problem
Old May 17, 2002 | 12:08 AM
JoeBlow's Avatar
JoeBlow
weird problem
Hey guys, here's one for you. everytime i make a sharp left hand turn, my truck surges with power. when i straighten back out, it goes back to normal. right hand tuns have no effect, just left handers. My truck is a 1979 f100 with the stock 302.
what do you guys think?..
Old May 17, 2002 | 10:30 AM
Jermafenser's Avatar
Jermafenser
weird problem
I'm guessing the carb...that is a weird problem. Sounds like fluid something.
Old May 17, 2002 | 10:52 AM
BB's Avatar
BB
weird problem
I think you should always drive turning left.
Old May 17, 2002 | 11:10 AM
KJKozak2's Avatar
KJKozak2
weird problem
When you say "surges with power", do you mean the engine revs up faster, or the truck lunges forward without a change in RPM?
Kevin K.
Old May 17, 2002 | 11:17 AM
beartracks's Avatar
beartracks
weird problem
I think you're gonna need a priest for that one!
Bear Tracks
Old May 22, 2002 | 11:06 PM
Dans75Ford's Avatar
Dans75Ford
weird problem
Older Fords, (around '62) I had one, had a thing with the carb that when you turned full left/right, a solenoid kicked the gas in to keep the engine from boggin down. You say that it just does it when you turn left? Sounds like linkage or float in the carb. Question, when you are sittin still, does it affect the revs?
Dan
Old May 23, 2002 | 08:23 AM
dfisher1's Avatar
dfisher1
weird problem
Joe,
Adjust your float. The 2-barrel is sensitive to float adjustment. Your's is set too high. You can remove the top cover and make your adjustments without removing the whole carb. Replace the float if you can afford it. Get ready to adjust it two or three times.
My Way is the Highway,
KinghFisher
Old May 23, 2002 | 09:03 AM
Vampiro's Avatar
Vampiro
weird problem
that's something i've never heard of. like King Fisher said it's probably your floats. maybe you might have to rebuild your carb?!
Old May 23, 2002 | 10:47 PM
Mike W's Avatar
Mike W
weird problem
The float would appear to be the problem. The float pivot is on the passenger side. You guys do the math.
Old Dec 19, 2002 | 11:40 PM
JoeBlow's Avatar
JoeBlow
weird problem
turns out that i had two spark plugs sparking on top of the passenger side header. when i made a left turn it would move them off. I am the biggest idiot in the world!!!!!
Old Dec 20, 2002 | 01:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
weird problem
But a HAPPY idiot! :-X12 -hehe
Thanks for letting us all in on the happy resolution of your problem.
I bet most people here have probably had a similar experience.
Merry Christmas!
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 20, 2002 | 07:09 AM
William's Avatar
William
weird problem
Not so fast! You have a motor mount problem or really loose crossmembers. Sounds like the headers are touching a cross member as well.
William in Atlanta
Old Dec 20, 2002 | 12:25 PM
JoeBlow's Avatar
JoeBlow
weird problem
I meant to say that the spark plug WIRE was laying on the header, not the plug. I have checked around the headers, and they are not too close to anything like that
Old Dec 20, 2002 | 03:58 PM
fearthis390's Avatar
fearthis390
weird problem
