Aerostar Ford Aerostar
Alternator Trouble Again
Old Jul 13, 2005 | 08:49 AM
Aftrmidnite's Avatar
Aftrmidnite
I replaced the brushes on my alternator and everything checked out okay. Now the Amp light is back on, gauge is on the "O" in NORMAL have 12.83 volts at the battery engine running at idle , 12.56 engine off. Checked my battery cells with a Refractometer, all okay. The marine battery charger/maintainer says everythings okay. On the back of the alternator one of the voltage regulator screws says, "Short to Test" what does this mean?
Also I'm using this check list. It's a 4.0L 94 with 95 amp alternator. When the Alternator is running it sounds like a sewing machine, its always been that way, but maybe noisier than when new. http://www.starteralternator.com/alt...ting_check.htm
Old Jul 13, 2005 | 12:00 PM
bertha66's Avatar
bertha66
I would pull it and have take it in and have it checked. You said you replaced the brushes, but it sounds like the bearings are bad.
Old Jul 13, 2005 | 01:08 PM
93nighthawk's Avatar
93nighthawk
While running your battery should be pumping out about 14.4v. I would go ahead and replace the battery and alternator at the same time to avoid any future issues.
Old Jul 13, 2005 | 01:13 PM
krankshaft's Avatar
krankshaft
My alternators bearings went last year and the charge gauge was on the O in Normal as well. Only at idle did the AMP light come on though but at idle I heard a rythmic squeaking and thats when charge was insufficent and the light came on. For the last 2 years there was a squeaking but I thought it was just a dry belt it turned out the alt bearings wore until the alt couldn't charge the battery.
I would also compare the prices on a new alternator if replacing the defective part costs more then half the value of the alt your probably better off getting a new one or to save even more money like I did an aftermarket rebuilt one.
I picked up a Duralast at Autozone and have had no problems they also refund a core charge of $20.00 to - $40.00 when you give them your old alt depending on the model.
Old Jul 13, 2005 | 01:21 PM
Aftrmidnite
I have an Napa near me, has anyone gotten an alternator there? Can't understand how the battery could be bad, as I checked the Specific Gravity of each cell with a refractometer and it takes a charge fine. I've worked with wet cells for years on UPS for computers. Bearings on the Alt. are smooth and quiet, but it's not worth putting a voltage regulator in it.
Old Jul 13, 2005 | 01:27 PM
93nighthawk
Here is what is happening, (and what will happen if you don't replace the battery with the alternator
1. Voltage regulator goes out on alternator.
2. Battery is overcharged numerous times
3. Finnally the dummy light comes on and you find out the regulator is toast.
4. You replace the alternator.
5. A couple months later your battery finnaly gives up the ghost.
6. You replace the battery, but the damage to the new alternator's regulator has been done.
7. A couple months go by and that dang alt light is on again because the reg is toast again.
Been there, done that, don't want to do it again.
Old Jul 13, 2005 | 07:36 PM
B-Aerostar's Avatar
B-Aerostar
Lightbulb
I changed mine to a Explorer 130 amp alt and its charging about the same as the 95 Aerostar at slightly over 14 volt
Old Jul 13, 2005 | 07:48 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
Just swap out the alternator and you should be good to go (assuming that you don't get a bad rebuilt alternator like I did!! Everything is cool now.). Good luck. i know how frustrating this can be!
Old Jul 13, 2005 | 08:07 PM
Aftrmidnite
It could be the bearinging are bad when you put a load on them, seen plenty of motors like that, even in brand new equipment. or the armature could be separating. Wouldn't show up in hi-pot or meg test. The battery will get checked again tomorrow, it is taking a charge tonight with the tender, and I've never had it misdiagnos a battery. Wish I had the battery load test device, we had at work.
Old Jul 13, 2005 | 09:27 PM
96_4wdr's Avatar
96_4wdr
The reason why alternators don't last in Aero's
Drive 100 miles on the freeway on a 100 degree day with the headlights on.
Pull off, turn off engine, reach in and put hand on alternator.
ghuns
Apr 14, 2019 07:25 AM
Carm84
Feb 24, 2017 03:37 PM
92 Red F150
Sep 16, 2014 09:12 PM
bigtexan99
Dec 22, 2011 07:37 PM
RANGER589
Electrical Systems/Wiring
May 24, 2011 02:11 PM
