Code P1289 anyone had this yet?
Old Jul 13, 2005 | 01:48 AM
svmirage's Avatar
svmirage
Hello, I am getting a P1289 code. Has anyone else run into this before? My vehicle of choice. 01 Excursion 2wd w/ a 5.4, so poorly equipped
Thanks, Ray
Old Jul 13, 2005 | 05:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 13, 2005 | 11:28 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
It indicates that the CHT (Cylinder Head Temp sensor) is reading high. It could be a bare spot in the wire, the wire unhooked and touching the engine or a bad sensor.
Does the temp gauge peg or read cold all of the time? If so, unplug the wire from the sensor see if the code goes away after resetting the computer and running the engine a bit. If so, replace the sensor.
Jimmy
cman1120
27
Feb 28, 2022 01:07 PM
maximerror
Aug 21, 2016 03:42 PM
F250Oldie
Jul 15, 2016 09:17 PM
Frank Valenzuela
New Member Introductions
Sep 24, 2015 03:59 PM
jrvance7
Modular V8 (4.6L, 5.4L)
Jul 27, 2011 05:13 PM
