Sponsored by: Real Truck
Power Door Lock Problems
Old Jul 12, 2005 | 09:56 PM
teg2_nv's Avatar
teg2_nv
My power door locks work sometimes and other times don't. One day the driver door will work, the next the rear left won't, etc. It is not the wiring because there is power going to them. Has anybody has this problem. Does it need a new actuators? Has anybody put in stronger aftermarkets ($10 vs $60ea.)?
Old Jul 12, 2005 | 10:01 PM
99f350sd's Avatar
99f350sd
The accuators do get weak. Since I see you have an 2000 you might need some..
Dick
RY54's Avatar
RY54
My pass. front, and driver rear dont work. When i hit the lock or unlock button you can see them try and move but dont go all the way. I just dont worry about it cause its not my door.
Old Jul 12, 2005 | 11:44 PM
WA.Ranger's Avatar
WA.Ranger
I need to replace my pass. rear. I found this, maybe it will help.
https://www.ford-trucks.com/forums/s...ghlight=cuinak
Old Jul 13, 2005 | 11:19 AM
Methos's Avatar
Methos
Yup, get a new set and follow the link posted by WA Ranger. Used those steps myself to change the one on the passenger side of my '00. I had looked at it twice and couldn't figure out how to get the part out to replace it until I found those instructions. Not a hard job, really, if you take your time.
As far as aftermarket replacement, I don't know for sure. I got mine from a ford dealer. But when I got the old one out I found that it looks a little different than the new one. Actually, it was different enough that I was a little worried about the new one working. But it did, so I have to wonder if there was a redesign done at some point because of this problem.
Old Jul 13, 2005 | 01:41 PM
rmilchman's Avatar
rmilchman
I just replaced one in my '02. As Methos said the new one looked different then the original. I was told Ford did a redesign due to a flaw.
Old Jul 13, 2005 | 03:58 PM
high ho silver's Avatar
high ho silver
Smile
I had the same problem with mine (also a 2000). Quote from local dealer was 59.00 until I told him that I could get the OEM Ford actuators on line from another Ford dealer in Fla. for 45.00. He quickly changed the price to 45.00 also. The aftermarket units are cheaper but I didn't want to spend the time trying to figure out how to install them since they don't simply replace the factory ones. The wiring is different and you have to hook some extra brackets up to locate them piggy back with the old ones.
