ccv mod done - how much mist..?
Old Jul 12, 2005 | 07:31 PM
SpringerPop's Avatar
SpringerPop
Steve,
I bought the Gates 3/4 inch heater hose from my parts house. I paid $1.29/ft, and initially bought 25 feet.
Pop
Old Jul 12, 2005 | 07:39 PM
johnny8's Avatar
johnny8
Originally Posted by Steve_250
One quart of blood
$5.98 for clamps
$1.29 for PVC
Priceless!
sorry... forgot about the quart of blood... dunno what that's worth..!
Old Jul 12, 2005 | 07:41 PM
Kwikkordead's Avatar
Kwikkordead
I would like to add, I think that sometime in the future I am going to tap into the upper area of the oil filler neck on the passenger side of the engine and put a breather there too. I don't know if it's really neccesary but I would be more comfortable knowing that both heads are getting ventilation.
Old Jul 12, 2005 | 07:42 PM
7.3whitemonsta's Avatar
7.3whitemonsta
how do you do the ccv mod, and does it really help???
Old Jul 12, 2005 | 07:43 PM
Steve_250's Avatar
Steve_250
Hmmm, maybe I'll just take that 3/4 black garden soaker hose (that I never use) and run it out.
Old Jul 12, 2005 | 07:44 PM
johnny8's Avatar
johnny8
very interesting observation... i don't know if it is needed either... but i suppose it couldn't hurt...
Old Jul 12, 2005 | 07:51 PM
Steve_250's Avatar
Steve_250
Doesn't it cross ventilate across the back?
How wet do ya think it's getting (with oil) on the bottom side of the cap?
Thinking it might blow too much out....
(Uh-ooh, thinking again..)
Old Jul 12, 2005 | 07:54 PM
bigdaddyTank's Avatar
bigdaddyTank
I have been wanting to do this, now yall have convinced me to do it this weekend. More pictures for the website
Old Jul 12, 2005 | 07:55 PM
johnny8's Avatar
johnny8
steve man... watch that thinking...! you'll get yourself in trouble...!
Old Jul 12, 2005 | 07:57 PM
johnny8's Avatar
johnny8
i'll take some pics and post tommorow... like i said... the toughest part is getting that "dog house" turned around and put back in... i would recomend just leaving it where it is... just swing the elbow hose down 90* and hook your extension hose to it..
Old Jul 12, 2005 | 08:06 PM
Steve_250's Avatar
Steve_250
Thinking? Get ME in trouble?
Yo Johnny, I was talking about the cap on the oil fill for the engine!
The bottom of THAT cap!
ROFL! You too funny John...
Not gonna turn the puppy pound around, I'll leave it like it is and run the super soaker hose back. Heck, haven't used it for 5 years, she will never know it's missing.
(huh? didn't we throw that out?)
Old Jul 12, 2005 | 08:24 PM
lukecline's Avatar
lukecline
Originally Posted by johnny8
ok, did the ccv mod last nite... i think the mosquitos got nearly a quart out of me before i was done... did the mod cheap... length of hose and a couple of hose clamps.. $5.98... 4" od pvc fitting... $1.29... that's it... i spliced the new hose to the original elbow with a little piece of junk gargen hose and sealed them together with electrical tape and a hose clamp... looks fine works fine... lining up the screws to get the cover back on was a trick... the 4" pvc fitting worked really well... best of all the fins on my turbo look GREAT..! nice and clean.. sharp... no nicks or chips at all...! so... here's the question for you guys... how much "mist" should be coming out... it pumps out pretty good on my mule... steady stream... but.. it's not really oily and i don't get more flow or pressure when the engine revs up... so... what has been your experience with this mod...? also... any recomendations for plumbing this into the exhaust...? what should i use and where should i tap into the exhaust..? thanks guys..!
I ahve 200k miles on my truck, installed ccv mod about 750 miles ago. I have no vapor coming out of vent and not even any oil residue on the inside of the hose at the end.
Old Jul 12, 2005 | 08:34 PM
  #28
johnny8's Avatar
johnny8
i would almost think your hose is kinked somewhere... mine lets out some serious vapor, but mostly when i first start it up.. i think it is just when the heat first gets going in the crankcase, there is some pressure made from that heat build up and it vents through the hose... once she heats up there is substantially less vapor... i would think i have a real blow by problem, but when i rev the engine there is NO difference in the amount of vapor that comes out... so my rings must be doing what they are supposed to...
Old Jul 12, 2005 | 09:14 PM
  #29
lukecline's Avatar
lukecline
its not kinked, i also run synthetic oil maybe that would have something to do with it?
Old Jul 12, 2005 | 09:24 PM
  #30
johnny8's Avatar
johnny8
i run syn oil as well.. i don't think that is it... dunno... maybe you are venting somewhere else also... i was a little concerned when i saw how much was coming out a first, but now i think it makes sense.. i'm just thinking about different places where i can have the hose run to.. i don't like it just coming down under the motor.. although.. it does draw some comments from people... i could make up all kinds of stories to tell people...
"ya.. that's just the new ford "hyper diesel"... it's turbo AND supercharged.. has dual everything.. makes 1000hp and 2000 lb feet of torque... will out pull a peterbuilt..." somebody would believe it...!
