Carb Spacer?
Old Jul 12, 2005 | 02:42 PM
jor's Avatar
jor
Carb Spacer?
I will be installing my rebuilt 390 pretty soon (.030 over, some head work, pretty rowdy cam and headers). I'm using an Edelbrock RPM Performer manifold and an Edelbrock 750 cfm carb. Do I need a carb spacer on this or can I just bolt the 750 directly to the manifold? Thanks.
jor
Old Jul 12, 2005 | 02:48 PM
bshackelford711's Avatar
bshackelford711
i posted this question about 2-3 days ago. I answer was yes use the carb spacer. It helps keep heat off the carb form the engine.
Old Jul 12, 2005 | 02:49 PM
bshackelford711
this is a link to the post
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-391337-carb%20spacer">carb spacer</a>
-Brandon-
Old Jul 12, 2005 | 02:51 PM
rusty70f100's Avatar
rusty70f100
Well, without the spacer heat soak becomes a problem. Basically what happens is, on a hot day, you go somewhere and shut the engine off. 15 minutes later, you come back out and the motor is flooded. What has happened is, the gasoline in the float bowl has boiled off, and went into the intake. With a carb spacer, the carb stays a little cooler, and the gasoline doesn't boil.
I've also seen a thick (like 1/2") foam rubber type gasket that can be used.
So I'd run some kind of spacer, preferably a short plastic one. You dont need a real huge one.
Old Jul 12, 2005 | 07:52 PM
jor's Avatar
jor
Thanks, guys. I'll go with one of those 1" phenolic open spacers.
jor
Old Jul 14, 2005 | 12:37 PM
kwanderi's Avatar
kwanderi
Use the open spacer for high end HP improvements and the 4 hole one for low end torque increase. I use the 4 hole and can tell the difference in the grunt provided off the line.
Keith
Old Jul 14, 2005 | 10:49 PM
jor's Avatar
jor
I bought a 1" open phenolic from Jegs and I have a 1" 4-hole one on an old intake. I'll try both and post on the results. Thanks.
jor
jor
Mar 14, 2016 10:45 PM
jor
Jul 16, 2005 01:30 PM
jor
Jun 30, 2005 08:27 PM
jor
Arizona Chapter
Sep 20, 2003 11:18 AM
jor
May 7, 2002 09:51 PM
