Locating and testing relay
Now to test the relay. Connect a wire from the negative battey cable to pin 86. Then connect a wire from the positive battery cable tto pin 85. As soon as you connect the wires you should hear a click. If you hear a click, this is telling you that the coil is ok. If you donot hear a click then the relay is bad. Next to test the contact, get a ohm meter out. Connect a wire from pin 85 to the positive battery cable, and a wire from pin 86 to the negative battery cable. Now hook the ohm meter up to the to remaining pins(87&30). If the ohm meter shows any reading higher than say .1 then the relay is bad.
Another way to test the relay is to just replace the old relay with a new one. If the wipers work then great. If they don't, atleast you know it is not the realy.
Here are two sites that explains how a relay works. It should help especialy if my explination made you more confused.
http://electronics.howstuffworks.com/relay.htm
http://www.bcae1.com/relays.htm
Now where the relay is located, i don't know but if someone else doesnt reply where it is, i'll do some diging and see if i can find were it is. The closes i can get you is the main fuse box. If you look in the owner's manual it should tell you witch socket is the Windshield washer relay. Also, Autozone does not have the wiring diargam for your Explorer.
Chris
Chris
So I'm looking at my wiring diagram off the Autozone web site, and I see no relays for any of the wiper features - even washer pump. It runs right off a fuse under the dash. Looks like power runs from the fuse through the switch directly to the washer pump motor and then to ground. There something call an internal governor in between the wiper motor and the switch on the steering column. Looks like this controls the wipers going on when you hit the wash button.
So check out your wiring diagram and if it's the same set up, you'll need to trace out the wires for a short or open. If everythings OK, your pump motor is bad. Like a $15 part.
Chris
