Downpipe question
Old Jul 11, 2005 | 09:13 PM
watermanh's Avatar
watermanh
Downpipe question
I just installed my downpipe, 3" from MBRP. Removing old pipe wasn't as bad as I thought (used a plasma cutter). But installing new pipe was a real PITA. My truck seems to have much less space at firewall than what I've been reading about here. My question: Is it OK for downpipe to contact exhaust manifold pipe? I can see light between pipes but I'm sure through vibration they contact. Thanks in advance, this site is the best, aloha.
Old Jul 11, 2005 | 09:40 PM
ltfox's Avatar
ltfox
Its not good for it to rub on the up-pipe. It'll wear a hole in both and you'll be pulling them back out. I guess you have a OBS truck?? I'd do a little more pushing and get more room. Those up-pipes ar'nt fun to get out.
Old Jul 12, 2005 | 01:10 AM
watermanh's Avatar
watermanh
Thanks Itfox, yep it's a OBS. I guess I'll wait until the weekend and take the thing out again. Thanks again, aloha.
Old Jul 12, 2005 | 03:19 AM
RedStroker6's Avatar
RedStroker6
plasma cutter...that would have been nice when i did mine....used a sawz-all with a 6 inch blade...DP ended up in 3 pieces. jsut bend on the firewall a little more, it'll fit in better.
Old Jul 12, 2005 | 12:10 PM
U_B_LO's Avatar
U_B_LO
People make more room at the firewall by tweaking it with a hammer or a Porta-Power. I have a van and have a 3" round down-pipe from the factory because of the doghouse.
Old Jul 12, 2005 | 04:25 PM
watermanh's Avatar
watermanh
Yeah the plasma made removal really easy, cut open the topside of downpipe and then cut through bottom side from inside out. Decided not to wait until the weekend, started today and going in with the porta power, thanks for the replies, aloha.
