transfer case oil change
Old Jul 11, 2005 | 04:56 PM
dubbz's Avatar
dubbz
I have a 2000 explorer 4x4 , I was wondering how often you change the tranfer case oil. How do you drain it, I see no drain plug.
Old Jul 11, 2005 | 11:04 PM
dybeepvw's Avatar
dybeepvw
On the back of the transfer case on lower right there is a drain plug. The fill plug is right above it. Take the plug out,if the fluid is dark and not pink then change it. It depends on how much you use the 4wd as to how often to change it. I don't use mine that much so about every 30 to 40 thousand miles.
Old Jul 11, 2005 | 11:14 PM
hdwideglide94's Avatar
hdwideglide94
The plugs to drain/fill mine on my 98 F150 can be turned by 3/8" drive ratchet (with no socket needed). The plugs have a square recess for you to put the ratchet into. Be careful, as these are aluminum (fairly soft and can be damaged).
Old Jul 12, 2005 | 12:58 AM
rollinXplorer's Avatar
rollinXplorer
You should also pick up one of these pumps to make your life easier.
http://automotive.hardwarestore.com/...p--648771.aspx
I learned the hard way… I used funnels, turkey basters, everything, and got very little fluid inside. This will do it painlessly.
Good luck,
Joe
Old Aug 4, 2005 | 04:19 PM
edward r's Avatar
edward r
i cant empasize enough .. be careful when you retighten the drain/fill plugs. any overtightening can crack the case (which a mechanic did on mine)....
gently does it!!!!!
willpjones
Aug 19, 2016 02:41 PM
Randallman
Modular V10 (6.8l)
25
Dec 5, 2012 06:33 AM
90pioneer
Nov 2, 2011 08:49 AM
AMG-SM
Aug 22, 2011 11:55 AM
rett8799
1997 - 2003 F150
Jan 21, 2005 12:19 AM
