Lights flickering
Old Dec 21, 2002 | 08:48 PM
1ole4d's Avatar
1ole4d
Lights flickering
I recently noticed that when I have my lights on at night they flicker. I noticed that ALL the lights, even the dash lights do this. Is this something to be concerned about?? I just don't want something like the alternator going out on me at night.
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old Dec 21, 2002 | 09:40 PM
Mike W's Avatar
Mike W
Lights flickering
I would find out what is going on. Put a voltmeter across the battery and see what the voltage is doing.
Old Dec 22, 2002 | 02:16 AM
masterbeavis's Avatar
masterbeavis
Lights flickering
I have had this happen to me in all of my older fords. I can't remember what it is, but I have had the charging system tested and have been told everything is OK. Just another case of when the mechanics around, the problem goes away. Take your truck to the parts house and have the charging system tested.
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Dec 22, 2002 | 02:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
Lights flickering
With age connections go bad. You probably have a rusted/corroded/loose connection somewhere. Since everything is doing it check the grounds first.
Thanks for using FTE!
Old Dec 22, 2002 | 02:41 AM
f150sleeper's Avatar
f150sleeper
Lights flickering
[updated:LAST EDITED ON 22-Dec-02 AT 03:46 AM (EST)]I had the same problem. It would only happen when I would floor it. So it really had me confused I checked the wiring all over found nothing. Then I pulled off my box because it was rusted out and havent had the problem since. Never found any bad wires either.
1979 F150 Custom 2wd C4 302 painted ford blue, bored .040 over, flat top pistons with valve reliefs, Edelbrock Performer cam, carb, and intake, stock heads, MSD Ready-To-Run distributor, MSD Blaster 2 coil, Edelbrock valve covers and air cleaner with K&N filter, Dynomax headers, dual exhaust with Flowmaster 40 Series mufflers, 38 gallon fuel tank(how i can drive it further than around the block) 9" rear end with 2.75 gears and open diff.
"You're only as fast as me until the light turns green"
Old Dec 22, 2002 | 07:03 PM
Supercab's Avatar
Supercab
Lights flickering
I've had this problem with several older Fords, and after checking, and cleaning the electricial contacts, still had the problem, folks said replace the voltage regulator, I did, and no more flickering!!
Old Dec 22, 2002 | 08:19 PM
Polkat's Avatar
Polkat
Lights flickering
Yea, it fixed the problem with my '73 as well. Some older regulators are still electro/mechanical and they tend to wear out. You can try adjusting them (it can be done) but considering the price of a new one is still pretty low, just swap it out!
Old Dec 22, 2002 | 08:51 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Lights flickering
had the same problem and it was regulater
Old Dec 27, 2002 | 05:44 PM
Spice's Avatar
Spice
Post Lights flickering
Check for rusty or corroded grounds on the frame. This is common on 4 x 4's with body lifts, although this might not be your situation.
Old Dec 27, 2002 | 06:31 PM
82F100SWB's Avatar
82F100SWB
Lights flickering
It's either the voltage regulator, or the circut breaker in the light switch, the circut breakers are integral to the switch, and, the reason I have relays in my system...
Check out the Whiter Whites, Brighter Brights article in the tech section by Steve Delanty: https://www.ford-trucks.com/articles/delanty/brighter_lights.html
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 8800LB GVWR 460/Edelbrock 1411
T19/BW 1345/3.55 geared Full Floater 10.25/Dana 50 TTB
265/75R16's on Whitespokes
78 F150, 351M/C6, eventually to have something done with it...
Old Dec 28, 2002 | 09:55 PM
macguyver's Avatar
macguyver
Lights flickering
Old Dec 29, 2002 | 07:13 PM
Green Streak's Avatar
Green Streak
Lights flickering
had the same problem in my 79. Replced the light switch with on from the wreckers, no problem since. Dont forget to reach up and depress the little button on top of the switch and pull the **** and shaft out of the switch first.
Old Dec 29, 2002 | 08:34 PM
walstam's Avatar
walstam
Lights flickering
The problem is definately in the continuity of your light feed. I don't much buy into the regulator theory simply becuase your battery still maintains a charge even if your regulator pulses the charge to the battery. A good battery can power your headlights for hours without being charged. My guess is the fault is somewhere between your battery's ground connection and the light switch since both your headlights and the instrument lights exhibit the same symptoms. I would disconnect the light switch and jump the connectors for your headlights and see if the problem remains. If it does, I would search for a bad ground connection. If it doesn't, replace the switch.
Jack
Old Dec 29, 2002 | 09:53 PM
Polkat's Avatar
Polkat
Lights flickering
I'd agree if the lights are truely flickering...going from normal brightness to much dimmer. But if there are pulsing...getting brighter then normal and then dimming, etc. then it could be the regulator, which if not properly controling the rate of charge, can be allowing too much voltage to the battery. Had this happen a few times over the years with both Ford and non-Ford, and every time a new regulator most definately fixed it.
Old Mar 30, 2004 | 09:06 AM
wckdclwn911's Avatar
wckdclwn911
Must be a common problem. My headlights would irregularly flicker along with my front turn signals and tail lights. I tried unhooking one bulb at a time until I pulled out the taillight on the drivers side. When I pulled it out the lights quit flickering and after replacing it, they seem to be working fine. It could have been in the socket also, but regardless its still working
