Brake job tutorial?
Old Jul 10, 2005 | 11:30 PM
jscozz's Avatar
jscozz
Brake job tutorial?
Sorry again if this has already been covered in another thread (the site will not let me search; says I have exceed my number of serches per session; for 7 days now! anyone know how to correct this?)
Anyway... I am looking for a tutorial or step-by-step on changing brakes (pads, rotors, calipers, etc.) on an Explorer or Expedition... I have always done most of my own basic work on my cars, but have never tackled a brake job... looking for some basics before I get into it...
I did some searches but did not find much on the web as far as turotials with pictures... if anyone can point me toward one I would appreciate it.
Jeff
Old Jul 10, 2005 | 11:37 PM
Monsta's Avatar
Monsta
Sit. Stay.
Check out this FTE article.
Although the author is replacing with aftermarket parts, the concepts and methods are the same for your stock replacment items.
Brake change article
Old Jul 11, 2005 | 07:07 PM
jscozz's Avatar
jscozz
Thanks, Ken.
I saw that article... it is a little sparse for a first time user... i.e. remove the calipers... a couple pictures and a few bullets describing how would be godo for me... same for rotors, etc. Anyone know of any more detailed description? Even a good book would be appreciated.
Jeff
Old Jul 12, 2005 | 04:59 PM
amm888's Avatar
amm888
have you taken a look at the chilton's or hayne's manuals you can get at autozone type stores? they're pretty basic, but should help.
al
Old Jul 13, 2005 | 09:56 PM
romac's Avatar
romac
https://www.ford-trucks.com/article/...2003_F150.html
or go to top of screen, click misc, then maintenance, then on right of screen click tech articles, and you'll see brakes
Old Jul 13, 2005 | 10:00 PM
romac's Avatar
romac
unscrew the top and bottom torx bolts to loosen the calipers. Open the caliper with say, a screwdriver to release and slide off to expose the old pads. and hang caliper with a wire or cord. Use a c clamp and an old pad to open the calipers all the way to put back on with ease after fitting the new pads. Whala, you're done.
