Aerostar Ford Aerostar
Rear Door Problems
Old Apr 16, 2009 | 04:44 PM
garywh's Avatar
garywh
Thanks Boz,,its in the lock, l cleaned up the oil from when they oiled the body and its working fine now,,,,thanks to yu
Old Apr 19, 2009 | 11:01 AM
bozzzz94's Avatar
bozzzz94
Gary-no worries. Sometimes that's all that is needed is a little oiling. Have a nice weekend
Old Apr 19, 2009 | 09:48 PM
Aeroman59's Avatar
Aeroman59
Post
Originally Posted by garywh
2001 ford door open light stays on after l use trunk,,l have to open and close quite a few times to get it to go out,,any advice on how to fix it??? THANKS
Switch is probably wired onto the Clasp, open the trunk & close the clasp fully ( by hand). Door Ajar light should go out when clasp is correctly closed (forms a near perfect circle). If it does not go out pull, the wire off at the terminal, if the light goes out normally the contact in the clasp is defective. Cant say if you can fix that. But you should be able to soak it in Kerosene & blow with an air gun to get any dirt soaked off of the switch contacts. Could also be that your trunk striker pin is incorrectly adjusted, not allowing the clasp to close fully. Try adjusting it........My son had this problem on his Mustang.
Aeroman.
Old Apr 20, 2009 | 11:44 AM
garywh's Avatar
garywh
THANKS AEROMAN,,,cleaned oil off with wd40,,and everything works now, warning light is out now to,,thanks again
Old Apr 21, 2009 | 10:09 AM
Bear River's Avatar
Bear River
Former ******
Once you clean it with WD-40, you should give it a liberal coating of white lithium grease. Otherwise the WD-40 residue will attract dirt back into the latch.
Old Apr 21, 2009 | 11:08 AM
garywh's Avatar
garywh
th yu Bearriver,,,did that and very sparingly,,gotta get this car fixed for her so l can jump in my f150 and head north fishing eh,,,,have a GOOD day
yozsi
Jan 9, 2017 02:20 PM
ct50f1
WTB - Ford Trucks & other vehicles
Aug 18, 2016 07:35 PM
greenf150flareside
Jan 9, 2016 07:17 PM
Cougar54
Oct 18, 2015 09:26 PM
scooterspal
Mar 20, 2012 09:47 PM
