1978 - 1996 Big Bronco
Tubes
Old Jul 10, 2005 | 03:59 PM
Fordbyford's Avatar
Fordbyford
Question Tubes
I'm putting my engine back together and I have 2 problems here I dont know where the PCV (Positive crack case valve) goes and theres a tube that goes on top of the EFI before the wire tree my pop said that the PCV valve goes into the male fitting wich Im talking about but it doesnt seem like it should go thether Im thinking that it should just hang loose My application is a 96 Bronco XLT 5.8W
Old Jul 11, 2005 | 05:15 AM
b4hntn's Avatar
b4hntn
I can feel my PCV valve but not see it. Passenger side of engine near firewall. It is on top of the valve cover underneath the intake. Due to inaccessibility, as long as there is some vacuum at the little hose going into the air filter box I'm not touching it. Haynes has a good view showing a "L" shaped hose attached to PCV. The hose attaches to a tube called intake manifold fitting assy which screws into the intake manifold against the firewall.
Pele
Oct 7, 2014 08:41 PM
tonefordays
Jan 16, 2014 07:56 AM
phurst
Jan 6, 2011 06:07 PM
CavsFan
Escape & Escape Hybrid
Aug 17, 2010 05:06 PM
tractoman
Mar 17, 2006 08:46 AM
