Well, between rains, I finally got the steps and cab corners cut enough to set the cab down about where I want it. Also cut off the frame horns even with the engine pulleys. Still need to put a notch in the fwd cab mounts, for a bit of clearance. Wouldn't like it if the hit the frame when I hit a bump!
Next step, build a crane to lift the cab back up, need to cut the old body mounts off the CV frame. Also need to get some RV leveling jacks to put under the frame before I build the new cab mounts.
Taking lots of pics, just haven't gotten them developed yet.
