i have been trying to find 2 new pulleys for my fe. i have been looking for a crank and a water pump pulley with 3 rows, for the air conditioning option. does any company make these aftermarket. i have only been able to find junk ones at the boneyards. they were either bent or broken. i have been able to find a ton of 400 and 460 pulleys but no good usable fe pulleys.was the a/c option rare on these?
need more info year of the truck would help but for the most part a/c was an option in fe years and not alot were made. look in xlt, ranger, exporer package trucks these trucks have more options than the rest. also check out cars that had a/c and fe galaxies are common for this.
I have not seen any in my searching for new aftermarket parts. March makes some FE pulleys, but non with the 3rd row for AC :-)
I just cleaned and painted my stock stuff. You might check with somebody like Old Air Products that make AC units for older vehicles. they must have a pulley source.
I'm in the same boat. I'm swapping a/c into my '73 F100 390 and have had trouble with the engine parts. I couldn't find new parts, but finally came across a set of good used 3 row pulleys for my FE and just painted them up. I'm still looking for the brackets to mount the compressor to the FE.
I had a 64 Galexie with a 352 with a/c, it had a 2 grove water pump pulley and a 2 grove pulley bolted to the crank witch gave it 3 groves. You my want to look with the Galexie or T-bird parts suppliers.
Marty
Marty, I may have the brackets and the old compressor from my 64 Galexie, PM me about these and I will look to see if they are around.
ford390gashog....I have a 3 row 7 1/4" dia crank pulley D3TE-6312-AB you can have for shipping cost only if interested. I'm not using it and it's yours if you need it. It's been kicking around here for years. Let me know if it works for your application. G.
