Pulled the cover to change the diff fluid, and my tag doesn't match up with what I remember these tags are supposed to read... can somebody give me a hand here?
Funny, I didn't see a LS pack in there... Maybe because it looks different than I'm used to... There is a stack of what look like big washers to the right of the spider gears, but it doesn't look like any LS I've ever seen, plus it's never worked. Do they offer a re-build kit for it?
Yup, thats a Ford LS. They are actually clutches and steels, not washers.
Mystery solved! Turns out the first "3" was under the bolt shoulder, and had been pressed out when the factory tightened the bolts. Luckily, the gear oil I picked was already LS compatible, but I'm still pretty sure it doesn't work. Is it worth it financially to fix the factory LS, or swap it for an aftermarket locker?
It feels like the driveline is loose. They unlock when not under power. If you drift around a turn it's like an open diff, put throttle to it and it's locked. Once in a while it will click real loud when it locks under power. It takes a little getting use to but I'm happy with it.
Do you have any problems with traction under power around corners in wet weather? I've only had a locker in a short wheel base truck, just wondering if the extra length keeps the rear end from getting so squirrely in the rain. Really like to get rid of my ls, but I'm not real fond of selectable lockers in the rear. Thanks.
IF I swapped it, I'd have to weigh the auto/selectable locker, as there are some times I want an open diff, but I know, in general, that auto lockers are a lot cheaper... Definately tired of getting stuck in a soft spot in somebody's front yard, though...
Thanks mech, I figured with the truck being that long it probably would be fine. I've been struggling back and forth between going to a locker or a good posi, I think you helped me make up my mind. Thanks for the info...
Max
BTW, sorry for hijacking a thread Rancha, but I figured it was sorta relevant, lol. Sorta...
I took my kid to school and got stuck on the pavement. RR was on ice and the LR was on wet blacktop. I had to get out and lock the hubs in. So much for the factory LS. The next weekend I swaped them both.
Yep, I've been in somewhat the same situation. Unfortunately, I was a long way from civilization (building pipe fence on a ranch), with a 2wd and no cell phone coverage. Took me forever to get unstuck from just sitting in wet grass and a little black mud. I think the locker would have done the job. Next time I'm buying a 4x4, no doubt about it. Just can't handle the price tag right now...
