Seat Belt Replacement
A couple of questions before I replace the buckle end of the driver's seat belt. How do I remove the plastic cover at the anchor end? It has a torx cutout. I can turn it but it does not loosen. I tried to pry it loose, but didn't want to apply more force until I knew that is the right way to do it. Also, what size torx wrench will I need for the anchor bolt? Thanks.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
the torx bolt cover is of the turn as you pry up design. turn it with a t-45(?) while prying up from the back side and it will twist right off. the bolt is a t-50, be sure to wd-40 that thing as it is exposed to the undercarriage.
just a note * do not apply heat to the underside of body where the bolt comes thru* i did that once on another vehicle when no lube would brake it free... story short it set the carpet on fire lol thank god for fire extingishers lol. part of that learning curve lol, did first then like omg what was i thinking kinda things
loudfords
General Automotive Discussion
26
Apr 29, 2008 02:51 PM
Outspoken1
1983 - 2012 Ranger & B-Series
Mar 2, 2007 09:07 AM
exstoker
Oct 31, 2004 09:12 PM
