97 Explorer Toe in Specs
Old 07-08-2005, 07:24 PM
Dave85zxt's Avatar
Dave85zxt
Dave85zxt is offline
Does anyone have the specs for toe in on a 97 explorer? The darn Haynes manual has only a few paragraphs on what toe in, camber and castor are. I would really like to put the finishing touches on the truck I just saved from the junk yard.
Also, does anyone know of a good site that steps you through a toe in adjustment and/or steering wheel alignment? Last time I did one was on a 92 Kenworth, I am betting its a little different and I don't want to miss anything!
Old 07-10-2005, 09:14 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
Dave, the Explorer alignment procedure is the same as on the Kenworth, you just use smaller tools.
My 2000 (97 would be the same), manual says toe-in specs are +.12*, with a positive limit of +.25*, and a negative limit of -.12*.
What this means is about a 1/16" to 1/8" toe-in is optimum, measured from the rear to the front of the tire.
As to centering the steering wheel, that's done by lengthening and shortening the tie rod ends. If the steering wheel needs to be moved to the right, then the left tie rod needs to be lengthened, and the right one shortened. (And vice-versa.) You do this by simply loosening the lock nuts, and turning the rods in and out, equally on both sides.
Good luck,
LR
Wolfracing
24
11-18-2017 05:00 PM
beaudog
06-29-2016 07:19 PM
Old Coyote
08-26-2015 11:37 PM
hhcobra
06-03-2012 09:38 AM
jrfiero
10-15-2010 03:48 PM
Quick Reply: 97 Explorer Toe in Specs
