stalling when put into drive?help!
Old Jul 8, 2005 | 10:25 AM
skinindstries69's Avatar
skinindstries69
Talking stalling when put into drive?help!
ok heres the thing, im a semi newb but im a truck guy, but i need some help on this one, ok i have a 1986 ford f250 v8 7.8l,start it up and it runs fine a lil choking at first but thats it,but when i put it into drive, the thing looses its idol and stalls, or it will drive if you rev it up around 2 and go, and eventually dies, what the hell, now when i got it i was told that the guy cracked the line to the radiator that cools the transmisson, thats an smiple fix but i wasnt running it enough to over heat and cease it up! can some one help me and tell me what i can or should do?? plz and thank you
Old Jul 8, 2005 | 02:27 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 9, 2005 | 08:59 PM
Cheggie's Avatar
Cheggie
If the truck only stalls in drive, and not park or neutral, you might have a bad torque convertor.Especially if you have an O/D transmission. It means you might get the truck moving if you rev it up enough, but it'll stall when you stop at a light. If this is the case, it'll idle fine in park and neutral.
Old Jul 10, 2005 | 08:50 PM
laughingman's Avatar
laughingman
Stall Problem
Hi. Recently on my 86 with the 460 V8 I had similar problem with engine stalling when put into drive. I found all my spark plugs had fouled and I wasn't getting enough spark from the duraspark box. After replacing these it was fine. Good Luck.
Old Jul 10, 2005 | 09:16 PM
skinindstries69
nah man all brand new plugs.... shyt you should have seen the ones that were in there lol, but myy uncle sayed it was the coil? cuz all the connections are clean now, but hte good news is that its only a 22$ part that he was talking about so yeah
Old Jul 12, 2005 | 09:06 PM
laughingman
Glad it was simple. This week mine would crank, finally start and blew cloud of black out the back and wouldn't stay running. Luckily the shop that rebuilt my carb last month towed and fixed it for free as the floats became stuck. So at least for now mine is running again...for at least the next ten minutes anyway! LOL
Old Jul 12, 2005 | 09:13 PM
skinindstries69
hah wow sounds like it needs a tune up, but your lucky oyu got it off easy ha but ryte now im working on my frigen rear tank! the line keeps snapping god dam and do you no how hard it is to keep dropping the tank?? o man, but 1 final thing is bad, the starter is a bitch! it keep slipping, my dad sayed it was something called a bending rod in it? i duno if can find the part for it or should i jsut buy a new starter uhgg
Old Jul 12, 2005 | 09:23 PM
laughingman
Hey skin........sounds like you're having way too much fun with your truck! The wife calls mine a POS all the time. No appreciation at all. LOL Well, depending on where you live you could try a salvage yard for another starter. Never did try and repair one myself. Usually just buy one and slap it in. But luckily this truck hasn't needed one yet. I sure hope the truck can't see this post and decide to follow suit with you......Anyway, hope yours finds the highway soon. Too hot here today for the road as it's 115 and I haven't recharged my a/c yet. Until nxt time........
