tranny filter
Old Jan 3, 2003 | 12:56 PM
gcfisher75's Avatar
gcfisher75
tranny filter
I have a 78 F150 and the C6 is leaking tranny fluid around the pan so I figured that I would just pull the pan, replace the filter and gasket and solve the problem. But I think that if I was remembering right that the back bolts were going to be a big pain in the butt, cause of the crossmember. I'm I thinking right? If I am is it just easier to put a jack under the tranny and pull the crossmember? Seems like a lot of work if I don't need to. I know how to change the filter and everything just was wonderin about those bolts. Thanks everyone who responds.
P/s: I am looking for a right front fender and a left door for the same truck in good shape. If anybody comes across one or the other please let me know. Thanks again.
Mine: 1978 F150, 4x4, auto, dual tanks.
Dads: (2) 1978 F150 4x4, auto,
1977 F150 fx4, 4spd
Old Jan 3, 2003 | 01:25 PM
cjcathey2002's Avatar
cjcathey2002
tranny filter
i just did a tranny fluid drain and replace like you are talking about in the last 5 months. did it in the alley behind my garage in about an hour. you just have to have very dexterous fingers and some fancy work with a socket set but its not too bad.plan on getting dirty, as mine was leaking also and it made for a lot of dirt and grime to fall on me. but you dont need to remove the crossmember, ford wouldnt design their trucks that way.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
msd 6a and blaster coil
Old Jan 3, 2003 | 01:29 PM
Quadiquizm's Avatar
Quadiquizm
tranny filter
I had no troubles with my C6 in my 79 f-150 2WD. Bolts were all there and easy to access.
Keep it Rubber Side Down!
Old Jan 3, 2003 | 02:14 PM
laptopgeek's Avatar
laptopgeek
tranny filter
gcfisher75 ---
I've used a 1/4" flexible 1/2" socket and extension for years - it lets you do the job withought moving the crossmember. PLUS you can have a handy tool for other jobs in the future, too....
(A man can NEVER have enough tools!!...)
Snap-on / Cornwell sells them...
Old Jan 3, 2003 | 02:27 PM
fordguy76's Avatar
fordguy76
tranny filter
yeah the pans on those 4x4 are kinda blocked at the back. we were going to change the filter on my brothers truck but didn't because of it
Old Jan 4, 2003 | 02:04 AM
GeneStoner's Avatar
GeneStoner
tranny filter
Spend an extra $5 and install a bolt-on drain plug in the pan while you have it out of your rig.
Old Jan 4, 2003 | 03:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
tranny filter
92cruisinblue
Jul 9, 2013 11:59 PM
yellowtonka2
Apr 4, 2013 09:59 AM
62stepside
Dec 19, 2002 07:04 PM
