windsor sb in 77 p/u
Old Jul 8, 2005 | 01:49 AM
sigsig's Avatar
sigsig
Question windsor sb in 77 p/u
Does anyone have any experience of fitting a 351W/E4OD/NP208 combo in a 77 long or shortbed pickup?
Old Jul 8, 2005 | 09:01 AM
trinogt's Avatar
trinogt
Do you mean an EFI 351W? I have had an E4OD on a 460 before, but didn;t know they used 'em on 351's too...
That would be a cool thing!
Mark
Old Jul 8, 2005 | 12:01 PM
kingford72's Avatar
kingford72
isn't the e4od computer controlled you also have to swap in the entire harness if your not keeping the EFI
Old Jul 8, 2005 | 01:29 PM
trinogt's Avatar
trinogt
I know the E4OD I had used a switch that shut off overdrive. Not sure about it being shift controlled by computer too... It was a 1990 Super E350 van. Basic EEC IV ECU, which I believe never had much say over shifts, unlike OBD II. (someone correct me if I'm wrong) So, maybe it can be used behind an older, carbed engine? Pretty heavy sucker though, lemme tell ya! I think an aftermarket AOD would be better for the 351W, and still take the power. (not stock AOD)
Mark
Old Jul 8, 2005 | 03:55 PM
F150daniel's Avatar
F150daniel
The E4OD is fully electronic controlled by the ECU.
You can get programable controller for it.
http://www.powertraincontrolsolutions.com/
http://www.becontrols.com/
I think(maybe) you have to grind the fins off the bell houseing to get it to fit on a 73-79.
Old Jul 8, 2005 | 04:06 PM
trinogt's Avatar
trinogt
I think the E4OD is 250 lbs or something crazy... Why not just use an AOD? Then you can use a carbed engine still; keeps the options open?
Couple years ago, it cost $2500 CAD to repair the E4OD in that van... It was really cratered. What would it have cost for a brand new unit? For the same money, you can get an all-out race AOD with awesome torque converter.
Mark
Old Jul 9, 2005 | 12:28 AM
deisele75's Avatar
deisele75
The AOD would be easier, but here is a thread on the E4OD
https://www.ford-trucks.com/forums/s...highlight=e4od
Old Jul 9, 2005 | 10:55 AM
trinogt's Avatar
trinogt
Sheesh, sounds like an awful lot to do! My E4OD was behind a 1990 EFI 460. I am sure it got the 1996 updates when rebuilt.
Just the sheer weight would make me think twice... I've bench pressed many a C6 on the driveway, but when I saw the E4OD, I almot passed out! lol
Sounds like a stand-alone controller for it. That could be a cool factor, but is it really worth the extra cost and work?
Mark
Old Jul 9, 2005 | 03:09 PM
LxMan1's Avatar
LxMan1
Well, the 351W will fit fine. My 77 have a 351W out of a 79 T-Bird in it when I got it. It now has a 77 460 in it
