Rev limiter?
Old Jul 7, 2005 | 08:36 PM
F150'89's Avatar
F150'89
Rev limiter?
I have a '89 f150 5.0 w/5sp and have never had it past 3000rpm until to day and when the rpms got to 3500 the engine started cutting out. Is this normal or is there a problem?
Old Jul 7, 2005 | 08:40 PM
Popa Tim's Avatar
Popa Tim
3500 rpms is low for a rev limiter unless its aftermarket; I'd hazard that you have a problem. Possibly the coil breaking down or in need of a good tuneup. 3500 isn't much if you had to downshift to pass someone on the highway.
Popa Tim
Old Jul 7, 2005 | 10:18 PM
F150'89's Avatar
F150'89
I have a new coil,module,wires,plugs and reman distributor. Engine runs/pulls strong and turns 2400rpm at 70mph and has plenty of power to pass at that speed in 5th gear. I also have a K&N filter and shorty headers with a single Flowmaster "40" muffler and the coil and module are Accel brand. The truck gets 15-16mpg with intown driving. Anyone else have this problem?
Old Jul 7, 2005 | 10:28 PM
landjr's Avatar
landjr
I would check the ignition just to be sure everything is set up right and also check the distributor and timing. My truck is a 95 5.0 auto and will turn more than 4000rpm with no problem.
Old Jul 8, 2005 | 02:24 PM
MustangGT221's Avatar
MustangGT221
The V-8s should spin to 5000-5500. My 89 351 has 140k miles on it and it has seen 5000 rpm a few times. The 302 I had in my F-150 spun to 5500 no problem.
When I put my 393 in, I had trouble with it cutting out at 3500 rpm. My timing was set wrong. It felt just like the fuel was cutting off and I thought I had inadequate fuel pumps for the beast. Turns out it was just my timing and after correcting it, it now runs up to 6000 rpm no problem.
Old Jul 8, 2005 | 02:52 PM
MemOrex's Avatar
MemOrex
6000 is the limit. I've had it up to 4500, but I got scared and shifted...lol
Old Jul 8, 2005 | 03:15 PM
MustangGT221
The stock rev limiter was set at 5500 rpm on my stock 302, and believe it or not it was set at that for the inline six as well (i've hit it). I havn't gone past 5000 on my 89, but it feels those high RPMs a little more than my 302. The 302 reved a little higher, probably because of the hydraulic roller lifters it has. The 89 doesn't have those, and seems less happy above 5000 rpm.
However, it doesn't make much sense to go past 4200-4500....the power has long dropped off by 5000 rpm.
Old Jul 8, 2005 | 08:26 PM
F150'89's Avatar
F150'89
I normally don't go above 3000rpm but I had a brain fart and pulled out in front of someone and realy got on the gas. I just checked the base timing and it is dead on 10*BTC. Maybe the timing chain has to much slack?
Old Jul 9, 2005 | 01:50 AM
MustangGT221
You had the SPOUT connector out when doing the timing, right?
Old Jul 9, 2005 | 05:56 AM
F150'89's Avatar
F150'89
Yes I did!
Old Jul 9, 2005 | 06:57 AM
frederic's Avatar
frederic
Agreed. I spun my 351W crewcab to 5000 last summer exactly once. Felt just like 3500 RPM, except with a lot more noise and I could have sworn I saw the fuel gauge move. ;-)
Old Jul 9, 2005 | 05:04 PM
Popa Tim's Avatar
Popa Tim
Did you widen your plug gap when you put in the accell stuff?
Old Jul 9, 2005 | 10:01 PM
F150'89's Avatar
F150'89
I set the plug gap at .050
1989lariat
Dec 30, 2014 02:56 PM
seths89f150
Aug 13, 2010 08:01 AM
seths89f150
Jun 22, 2010 06:17 AM
Brown89f150
May 8, 2004 04:32 PM
Phillip Guidry
Mar 13, 2000 11:31 PM
