engine identification
Old Jul 7, 2005 | 08:07 PM
77fordcrewcab's Avatar
77fordcrewcab
I have just picked up a 78 F-100 the guy that i bought it from said that it had a 302 in it. I don't think that this is true. I think that it is a 335 series. a 351m or 400. what is the most noticable diference between a 302 and 351m or 400?
Old Jul 7, 2005 | 08:09 PM
ford390gashog's Avatar
ford390gashog
the size. a 302 is pretty small.what are the casting codes.
Old Jul 7, 2005 | 08:12 PM
77fordcrewcab
engine is vary dirty. were would that be located
Old Jul 7, 2005 | 09:38 PM
coolmint94's Avatar
coolmint94
uh, look on the valve cover...or on one of the edges of the heads, if its a 351M/400 itll have an M cast into the head or you can always post the VIN and someone will decipher it....check the door jamb for that...
Old Jul 7, 2005 | 11:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
-There are other indicators but these are enough to distinguish engine families.
Old Jul 11, 2005 | 02:55 PM
spikedog's Avatar
spikedog
Thanks for the good info, Torque1st. I was just looking at a '71 Mustang Mach 1 - all the numbers check out as a 4V-351C, but the owner says she had to replace a cracked block. Made me wonder if something else was put in the engine bay.
Old Jul 13, 2005 | 10:02 PM
77fordcrewcab
I have nerowed it down to were it is an M block except that there is no M on the head. Are there some that don't have the M stamped on the head?
