Auto zone lists only one part number for a 96 but 2 for a 93. Not sure what the difference is. You can call a Ford dealer and ask him to check if they are the same.
Question though - why do you suspect a or all bad injectors? I had a sligh miss that eventually go real bad and it ended up being bad wires. Sure felt like a bad injector but no.
Well then probably not all your injectors. Check your plugs when it's running bad and try to isolate the one or 2 cylinders. This can save you some bucks. But if you can get a set of new ones for $35 - heck, no brainer.
