Need C6 info please
Old Jul 6, 2005 | 08:07 PM
n2music's Avatar
n2music
Need C6 info please
I just purchased a C6 tranny for my truck and want to know for certain that everything gets hooked up correctly. There are two lines that connect to the side of the transmission. Please tell me which one is the sending and which one is the return. I also have a radiator that has the transmission lines on the bottom side of the tank and would like to know which one is recieving and which is sending. I also bought a new torque converter for it and was told that if you do not install these properly that as soon as you start the engine, you could burn up the trans. pump, so please give me some instruction on doing this as well. Thanks in advance for any help.
Old Jul 6, 2005 | 09:43 PM
rclarke's Avatar
rclarke
The line at the front of the tranny is hot oil from the torque converter, the rear line is the return.
Old Jul 6, 2005 | 10:02 PM
n2music's Avatar
n2music
Thanks, Does anyone know about the radiator?
Old Jul 6, 2005 | 11:02 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
It does not matter with the radiator. If it were my truck I would add a cooler but still use the radiator cooler in the circuit.
Flush the radiator cooler, pressure and leak check to prevent a trans failure in the future. Is this a 1/2 or 3/4 ton? Use the correct tailshaft case.
.....=o&o>.....
Old Jul 7, 2005 | 07:46 PM
n2music's Avatar
n2music
OK, Thanks.
snailplow
Apr 6, 2014 10:25 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
25
Feb 14, 2013 05:51 PM
towsrus
Dec 24, 2010 05:14 PM
53fatfndr
Jul 4, 2004 01:49 AM
Sportcustom69
Oct 11, 2002 09:20 PM
