Drivshaft assy
Old Jul 6, 2005 | 07:56 PM
mouse777's Avatar
mouse777
Drivshaft assy
When a single driveshaft is assembled, the pivot points on the shaft are parallel. am I right in assuming a two piece driveshaft will have all three pivot points in the same plane? Thankyou in advance. mouse
Old Jul 6, 2005 | 10:11 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
the trans to front shaft has a minimal angle same as well the center joint but the rear joint will be 3 to 4 degrees more to allow for rear axle wrap up under torque and cargo loads. Been running F 250's over 36 years and 900K plus miles empty without U joint problems. Don't worry about it unless you lifted the truck.
.....=o&o>.....
