4X4 Problems
Old Jul 6, 2005 | 11:39 AM
Shadetree101's Avatar
Shadetree101
Question 4X4 Problems
I have a 2001 B4000 Mazda truck. The 4X4 transfer case motor no longer engages, dash light indicator for 2w high, 4w high, and 4w low no longer works. In fact I had to remove the transfer motor and physically engage it back to 2 wheel high. I have checked: fuses, electrically jumped the transfer motor (it works fine), looked at harness connections and I finally located the electronic shift control module after removing the passengers kick panel (Hanes Manual said driver side). The Hanes Manual, as far as trouble shooting in this area leaves little to be desired as well as my electrical experience. HELP!
Old Sep 1, 2005 | 08:35 PM
KENS94F1504*4's Avatar
KENS94F1504*4
shadetree.....did you figure out what it was??i have a f150 with same issue
