Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ABS Light/Brake light on
Old Jul 5, 2005 | 08:08 PM
hdman6's Avatar
hdman6
Cool ABS Light/Brake light on
My ABS light is on steady and then 20 minutes later the brake light comes on and stays on. The manual says to take it to the dealer right away(of course).
Aybody have this issue? We just had it at the dealer and they put new rotors and pads on the escape (20,000 miles ago). Anybody have any ideas as to what this might be. We did purchase the Extended warranty which covers all sensors etx related to ABS braking system. also its a 2002 escape with 40,000 miles on it. thanks Jeff
Old Jul 5, 2005 | 08:25 PM
mrshark's Avatar
mrshark
HD-
We had the same problem with my wife's 2003 Escape last year. Apparently a wire connecting to an ABS sensor popped off, causing the lights in the dash to stay on. Brought it to the dealer, was fixed in about 1 hour. In our case, the dealer said it wasn't a safety issue, the wire would not have caused the brakes to fail. I wouldn't take any chances though....bring it in ASAP.
-Mrshark
Old Jul 5, 2005 | 08:58 PM
Beast12's Avatar
Beast12
I know on some of the older vehicles if you were low on brake fluid the brake light would come on. Wouldn't hurt to check...
Good luck!
-Matt
Old Jul 9, 2005 | 08:17 AM
bananaboat's Avatar
bananaboat
To add to Beast12's comment - on the early s, sometimes you have to put a little extra fluid - over the line. If the warranty covers the reservoir then make them replace it. I believe Ford was charging around $300 just for the part.
Old Jul 9, 2005 | 12:32 PM
bumpzter's Avatar
bumpzter
I agree with the comment about low brake fluid. Had it myself. But only the brake light came on. Not the ABS light. That must be something different.
Old Jul 9, 2005 | 06:34 PM
bananaboat's Avatar
bananaboat
True. I had a brain lapse. That was the brake light I was thinking about.
Power Stroke 7107
Jan 17, 2018 07:37 PM
radioman13
Oct 5, 2016 10:22 AM
escapetonering
19
Jun 22, 2016 05:08 AM
mattswabb
May 3, 2015 04:09 PM
Gr8cub
Mar 25, 2014 05:43 AM
