351C or W?
Old Jul 5, 2005 | 09:56 AM
wilddog's Avatar
wilddog
351C or W?
What is the difference between a 351 c and w? What application is each better for and why?
Old Jul 5, 2005 | 11:29 AM
Kruse's Avatar
Kruse
In a nutshell......EVERYTHING, almost. The 351W is just an overgrown 289/302. The 351C is a special engine that shares parts with the 400. The 351W has parallel valves. The 351C has canted or semi-hemi valves. The performance of the 351C was killed because of the emission requirements of the 70's.
Old Jul 5, 2005 | 01:02 PM
Purely Ford's Avatar
Purely Ford
A 351C was not built to be a workhorse, but built for higher RPMs and speed whereas a 351W is a better all around workhorse. The 351C has smaller main crankshaft journals which is better for high RPMs (less friction and heat buildup). The 351W crankshaft has larger main bearing journals which are good for heavy load pulling applications like trucks.
Even though the W was a better workhorse, they never came with a 4 bolt main block like some Cs did.
The higher performance of stock 351C was never paralleled by a stock 351W in the 70s. Also, both C and W engines suffered from emissions requirements simultaneously not to mention all of the other engine families as well.
To sum it up, a 351C has better high RPM breathing abilities and a 351W has better low RPM towing abilities.
Old Jul 5, 2005 | 02:02 PM
Titantis's Avatar
Titantis
The 351 cleveland is a big-block engine isn't it?
Old Jul 6, 2005 | 01:56 AM
Purely Ford
No, it isn't. It is a 335 series engine. I don't use the terms big-block or small-block much if at all especially here at FTE.
Ford engines are identified by families or series. If one had to label a 351C as a big or a small-block it is neither of them really, but more precisely an intermediate block. It is a wider engine than a 351W, but uses the same motor mounts as a 302, 351W. Also, the bell housing bolt patterns are identical for a 351C, 302, 351W, 240 I6, 300 I6. There may be a few other engines with the same bell housing and motor mount bolt patterns, but I can't recall them right now.
Old Jul 6, 2005 | 08:41 AM
ronclark's Avatar
ronclark
It is the 351m that has the large bolt pattern bell housing. A lot of people mistake them for 351c because the 351m uses the 351c style heads.
gettler
46
Dec 16, 2019 02:51 PM
c_cort
31
Apr 10, 2008 01:41 PM
rbastedo
Jun 8, 2004 07:58 PM
jec27
Oct 20, 2003 08:32 PM
AlM
1978 - 1996 Big Bronco
Mar 12, 2000 09:22 AM
