Reverse Parking Sensor problem
Old Jul 4, 2005 | 04:20 PM
cliff191's Avatar
cliff191
Has anyone been able to fix a RPS problem without taking it to FORD?
One day my system just stopped working. It was a dry day etc, and they were working fine before. I am not sure if a single sensor may be bad, causing the system to malfunction, or the switch in the dash is bad, or whatever.
Any ideas?
TIA
Cliff
Old Jul 4, 2005 | 07:06 PM
slc10844's Avatar
slc10844
Does the system turn itself off when you put it in reverse? Mine did and the dealer replaced one sensor. Works fine now. Seems to be a common problem.
Old Jul 5, 2005 | 02:01 AM
cliff191's Avatar
cliff191
In the last week, when I put the truck in reverse, I have only heard a single beep twice. All of the other times, no noise is made whatsoever. I might put an ohmmeter on the sensors and see if one has a reading different from the rest if this is possible.
Thanks
Cliff
Old Jul 5, 2005 | 04:50 PM
JOE-M's Avatar
JOE-M
I've tried to figure out how to test these ever since you posted about it. I looked at the wiring diagrams today and still couldn't figure it out. I checked the fuse panel drawings in the book and can't even find a fuse labeled for them. The only thing I discovered is when you cut the key on the "OFF" light will do a self test like the rest of the dash lights do. If it doesn't then there shouldn't be any power to them. I"d like to know how you fix them so if I have this problem I'll have a clue which direction to go.
Joe
Old Jul 14, 2005 | 07:50 AM
bartcooke's Avatar
bartcooke
sensor
My 2001 F250 is having a problem with the reverse sensor, seems like its in the dash board switch. When I start the truck, sometimes it's off and I can push the switch just right and it will come back on, but will go back off.
Bart
Old Jul 14, 2005 | 03:28 PM
slc10844's Avatar
slc10844
Bart
Same symptom as mine. It was a rear sensor. I don't know how much they cost, but it may be worth it to buy one and rotate through until you find the bad one.
Old Jul 14, 2005 | 09:57 PM
watersurgeon's Avatar
watersurgeon
The sensors have individual connectors behind the bumper, which connect to a main wire harness by the spare. Just pull each sensor and run a volt meter on it. Check for resistance. They should all measure the same. Also check the connectors. There not very water proof so there is a good chance your problem is just dirty contacts. Get some electrical spray cleaner, (radio shack) and spray out each connector.
Cost of sensors run from $22.00-$50.00 depending on the dealer. I had the same problem, it was a bad sensor. Unfortunately when one goes bad the whole system malfunctions.
Old Jul 15, 2005 | 07:06 PM
bartcooke's Avatar
bartcooke
Thanks for the feedback. I'll try checking for bad connections at the sensors first.
CLIFF1989
23
Nov 19, 2009 05:28 PM
tanman722001
North Carolina Chapter
Apr 11, 2008 10:21 PM
ncfirefighter46
Dec 17, 2006 12:32 PM
MAKO314
Sep 3, 2006 10:26 AM
ncfirefighter46
Jul 23, 2006 09:42 PM
