yes there is a danger of electrical shock if there is no ground. you should only have to turn off that circut, but first test it for ground/shorts using an multi-meter before connecting the ground. if you are not sure of what to do call a licensed electrician.
A friend on mines wife just bought him an wiindow a/c unit inwhich he installed.
The problem is that the 3 prong outlet is NOT grounded.
His son was barefooted on the cement slab outside and touched the a/c unit and got a slight tingling sensation.
We got his pen type non-contact tester and put it near the a/c unit.
It lit up.
There's a ground wire disconnected inside his electrical panel.
I won't go inside to re-attach it because there's no main breaker to shut off the power.
Maybe I'll run a ground wire from the outlet to the nearest cold water pipe.
Would that help?
Is there a danger of a severe electrical shock if the a/c unit is ungrounded ?
Holy Moly ! Yes as said above , get a circuit to it that carrys a equipment grounding conductor in it. I would recommend shutting that ac down now, it may go full voltage to the frame at any time, and will not trip the fuse/breaker.. The equipment ground is meant to take any fault current in an appliance to earth ground, causing a overcurrent draw which will then trip the circuit protection. That unit has a serious voltage to ground fault in it now, which is probaly as high as 90 volts, if a neon test light lit, and a human felt it also. I can feel 50 volt ac in my hand when grounded,
I am not an electrician, but I don't believe a new a/c should be giving any shock, unless its not wired correctly. Is it 110 or 220? Check to make sure that the outlet and A/c pigtail are wired correctly. I would get an electrician if your that uncomfortable. There are too many things that we cannot see that could be doing this.
First of all Ben, what are you doing with A/C in the Bay Area? Did it get up to a scorching 80 degrees there and you guys are all burning up?
Seriously, you need to get that ground wire hooked up, and soon! If you can see it disconnected in the main panel, then it's easy to see where it goes but I have to wonder whay it was disconnected in the first place. Maybe there's a short and it trips the breaker, and that was someone's idea of a quick fix.
Anyway, some good advice above, if you're not comfortable messing with it, have your friend get someone who is. If you like, I can PM you with a contact for an old friend down there who has a home fix-it type of business and does that sort of thing all the time. Let me know, -TD
A/C in S.F.? Un-heard of.
It's a buddy of mine in San Anselmo, Ca.
I'm going to forward these posts to him.
I'm just wondering why a ground wire was disconnected inside his circuit breaker box.
I never seen a circuit panel with NO main circuit breakers.
I guess he could pop off the meter. Naw!
I'll tell him to call an electrician instead.
And thankyou everyone for your input on this serious matter.
I will call him tonight and tell him to unplug it and get it fixed right.
It's 110 and the outlet is wired correctly; just no ground. Most of the house has un-grounded outlets including their computers.
What we are trying to say is the A/C, with or without the ground wire hooked up, should not be giving a shock. The ground is there in case there is a short somewhere in the A/C or outlet. As some pointed out earlier, why is the ground wire disconnected? There could also be a short in the run to the outlet or something else plugged into outlet. Is the A/C unit new or used? Gotta run. Finally getting some rain or at least a storm. Good Luck.
Friends A/C unit is new.
I to am also wondering why the ground wire is disconnected.
Previous owner did do some gonzo-bozo electrical work.
The oulet most assuredly needs checked out by a electrician and wired properly, if it is a new unit that is shocking people. Sounds like reversed polarity on the receptacle wiring, or a loose circuit neutral, a loose conductor or abraded insulation on a conductor in the AC that is touching the frame, or a, or a, on and on......... Hey, one more post and I got 1000 posts !!!
From what I understand, the new A/C unit shocks you if you ground yourself then touch the A/C unit. I heard it was more like a tingly sensation.
I'm just going to call him and advise him to call an electrician and fix the problem.
