timing gear set
Old Jul 3, 2005 | 07:47 PM
78_ford_F150's Avatar
78_ford_F150
timing gear set
to switch from a timing chain to gears is there any problems that i might have or is it just a simple bolt up
thanx
Old Jul 4, 2005 | 05:52 PM
53fatfndr's Avatar
53fatfndr
A remember a thread on this a while back. Do a search and see what you come up with.
Old Jul 4, 2005 | 08:09 PM
mark a.'s Avatar
mark a.
What brand of gear drive are you talking about ?
Old Jul 4, 2005 | 10:41 PM
good 'ol ford's Avatar
good 'ol ford
well as far as i know pete jackson is the only company that makes gear set for a 335series motor. i know this bc im looking at doing it for my motor. and i think if i remember right the only modification u have to do is grind down the axles for the idler gears but idk for sure
Old Jul 5, 2005 | 07:44 AM
mark a.'s Avatar
mark a.
Milidon made one that needed machining on the block. You will need to do something about the fuel pump eccentric, if tou aren't running a electric pump.
