4 barrel intake
Old 07-03-2005, 01:05 PM
Scoarch's Avatar
Scoarch
Scoarch is offline
4 barrel intake
is there a 4-barrel intake for the ford 4.0 ?
Old 07-04-2005, 01:53 PM
bigswede's Avatar
bigswede
bigswede is offline
Doubtfull. If there is it`s mega bucks. If you`re crafty you could try to fab one out of sheetmetal like the dragracers do.
Old 07-05-2005, 06:38 PM
Jharger's Avatar
Jharger
Jharger is offline
Not sure your application but it might be easier to get a EEC-IV or EEC-V computer, wire harness and a custom chip running the EFI system. Gets plenty of HP.
Old 07-05-2005, 08:17 PM
Scoarch's Avatar
Scoarch
Scoarch is offline
ya, thats what i told my dad but he wants to put it in a 1928 model A. he is old school and wants to go with a carb. the car has a 2.8 in it right now.
Old 07-06-2005, 10:23 AM
Jharger's Avatar
Jharger
Jharger is offline
Well at least he's not going with a chevy 350!
Old 07-07-2005, 01:31 AM
Scoarch's Avatar
Scoarch
Scoarch is offline
HOLY CRAP BATMAN !!! A chevy in a ford is a sin in my books and his. .
Old 07-07-2005, 12:16 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
Well... The problem I think you'll run into is that the 4.0L was never produced with a distributor. You need the computer to control the coil packs. I think you're pretty well stuck. I dont know if the 4.0L block still has the provisions for a distributor or not, but I doubt it.
I'd put serious thought into going to a 302 if there's room for one.
Old 07-07-2005, 12:24 PM
Jharger's Avatar
Jharger
Jharger is offline
Agreed - so many more options and even when you go 302 EFI. A9L computers are a dime a dozen.
4.0 has a camshaft position sensor, later ones anyway. It also runs the oil pump. Not sure if any distributors were ever designed to pop into this spot at the back right side of the motor.
Old 07-07-2005, 07:17 PM
Scoarch's Avatar
Scoarch
Scoarch is offline
i thought early 4 liters had a dizzy.
Old 07-08-2005, 10:46 AM
Jharger's Avatar
Jharger
Jharger is offline
91 and mybe 92 Explorers used only the crankshaft position sensor then 93+ used the camshaft. Mine is a 93 CA truck and it has the cam sensor. Maybe, not sure, but maybe all year CA had the camshaft sensor. Reason is CARB and smog control. I know CA used sequential fuel injection (each injector fires independent) and Fed used multiport (each R/L bank fires injectors at the same time). So perhaps a cam sensor is more accurate for use on the sequential?
Old 07-10-2005, 11:59 AM
rusty70f100
I do know that some marine engines used carburetors and distributors on late model engines. I dont know if the 4.0L ford was ever used in a marine application, but it might be worth checking into.
Old 08-05-2005, 04:12 PM
CourierBaha's Avatar
CourierBaha
CourierBaha is offline
They’re a few companies’ that make stand-alone IG systems for running coil packs with carb apps… but they are mega bucks.
Old 02-15-2006, 03:43 PM
sat2mmt's Avatar
sat2mmt
sat2mmt is offline
No one has ever produced a carb manifold specifically for the 4.0, unless it was a one of that I haven't heard of. The only thing that might come close is the 2 and 4 barrel manifolds made by offenhauser that were produced for the earlier 2.6 cologne v6. I've heard that these manifolds work on the 2.9 with some modification, and considering the similarities between the 2.9 and 4.0 it might be possible, although I don't know how the ignition system can be overcome. The 2.8 with a fairly aggressive cam and a 4 barrel offenhauser intake with a 390 holley can actually make lots of power, so modifying what is already installed might not be a bad idea. Just a thought.
Old 02-16-2006, 07:01 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome sat2mmt to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 02-24-2006, 09:49 PM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
I have looked into carbing a 2.9 extensively and The 4.0 would not be much different. The 4.0 Never came with a distributor. The 4.0 block is just a modified 2.9 block and the 2.9 distributor will work, only the deck height is different on the 4.0. The bad news is that nobody makes a standalone 2.9 distributor for use without the computer. The 2.8 distributor wont work because it has a different gear and oil pump drive. I have tried to modify a 2.8 distributor by putting the 2.9 gear on it, but the shaft diameter is different. this was the point that I gave up because just making the distributor work entailed almost a complete fabrication of a new dist. Another difficult aspect of this conversion would be the intake because the manifold also partially covered by the valve covers, so even a custom sheet metal manifold would require some machine work as well as welding.
Quick Reply: 4 barrel intake
