Sponsored by: Kumho
Stripped Bleeder Valve
Old Jul 3, 2005 | 12:47 PM
Mike38's Avatar
Mike38
Does anybody know of any tricks to at least be able to open and close it to bleed my brakes? Turns out the moron who owned the truck before me tightened it to the point he stripped it Its on the left rear drum of a 10.25 sterling. Any ideas would be greatly appreciated.
Mike
Old Jul 3, 2005 | 01:29 PM
Mike38's Avatar
Mike38
Bigger Problem
Well, things just went from bad to worse. After I saw the stripped bleeder, I went around WD-40'ing the other valves (btw I did bleed the RR...). So I let it set in and about a half hour later I went outside and tried to losen the front ones. The left front...no problems, the right front BROKE OFF! So my question is, now what do I do? Look for a new caliper? Or can it be fixed...its bad though, broke off right under the nut part right at the caliper. Worst part is I used the 3/8 wrench that is not even 6" long and it broke. I dunno what I'm gonna do now.
Mike
Old Jul 3, 2005 | 09:50 PM
luvthesnow's Avatar
luvthesnow
Mike
If fluid isn't dribbling out at least it's still driveable. Broke a bleeder on one of my calipers and did get it drilled out and re-tapped, but ending up replacing it anyway when I saw what the pistons looked like when I tried to do a rebuild on it. I like to tear stuff apart and fix it cheaply. A rebuild kit was less than $12. But it is just easier these days to buy a rebuilt caliper with new pistons and boots, sliding pins and anti rattle clip. Cost was $62 I think from NAPA. The core cost is going way up these days. $55.
Sooooo, you can fight your way through it by drilling out the screw (try a left hand bit, but more cost again) and trying an easy out (which never work for me at all). You might get lucky and another 2 bucks for a new bleeder screw and you are set.
Brian
Old Jul 3, 2005 | 10:38 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
ya i think its not worth the time to mess with trying to fix when rebuilt ones r so cheap. plus your old caliper piston prolly isnt real good anymore. ive had both my front calipers stick on with my truck. it's a good investment to put rebuilt calipers on an old truck, just for the fact u no they arent all coroded and stuff and stick on in the middle of a huge rainstorm on the way to work (which happened to me). i like to take all of my bleeder screws out and clean em up every year or two and suck out the master cylinder resv. and put new fluid in and then bleed all the brakes to get the old fluid out. that will do wonders keeping moisture out and preventing corrosion inside the brake hydraulic system, plus u no your bleeders will open next time u need them to.
Old Jul 3, 2005 | 11:45 PM
Mike38's Avatar
Mike38
Yea, I'm going to try to easy-out them. If I don't have any luck with that then its off for new calipers up front. Problem is I got this truck maybe a year ago and this is the first time I've touched the brakes, been too busy fixing the ignition system til now. But I'll give that a try tomorrow let y'all know how it goes, thanks again.
Mike
07F250MAN
Apr 12, 2010 01:44 PM
GARLAN111
Dec 31, 2007 02:02 PM
1FineBroncoBabe
79
Mar 4, 2006 03:09 PM
Mike38
Jul 9, 2005 07:21 PM
Mike38
16
Jan 1, 2005 09:05 AM
