ranger alt problem
Old Jul 3, 2005 | 09:30 AM
detour74's Avatar
detour74
ranger alt problem
replaced alt. because the parts store said they couldnt check old one, and i had no voltage at the volt gauge in the dash. the new one didnt work either. it is still putting out only 12.3 volts, any ideas what colud be the problem?
Old Jul 3, 2005 | 10:32 AM
pawpaw's Avatar
pawpaw
Welcome to FTE Detour. Why not run this ride by your favorite autoparts store, like Advance Auto, AutoZone, ect & have them do a no cost electrical system check up on the vehicle, with everything in place, with their portable test machine. It'll likely be able to pinpoint the problem. Could be any of a number of things, from a faulty new alternator, slipping belt, bad high resistance battery cables, to loose dirty corroded cable connections at the battery, or ground connections to the block. Let us know what you find.
Old Jul 3, 2005 | 12:50 PM
jimw411's Avatar
jimw411
IT should be putting out 14.6 when that battery has a full charge and with nothing on but the engine itself. I've heard of alternators not working proberly from the wire from the computer that goes to the alternator not putting out a good signal. Thats only a shot in the dark, it was a problem on my 99 toyota corolla i drive for work. Pull the codes off the ECM and go from there.
Old Jul 4, 2005 | 07:56 AM
ol yeller's Avatar
ol yeller
The clip that hooks on the alt could be bad. That is known to happen on the rangers.
Old Jul 4, 2005 | 10:45 AM
87 XLT's Avatar
87 XLT
Have you checked the fuse between the starter relay & alternator? On a 97, it's in the power distribution box under the hood.
Old Jul 4, 2005 | 02:54 PM
detour74's Avatar
detour74
hey thanks for all the help, found the problem, was a fuse in the distribution block(thanks 87 xlt), love this forum keep up the good work!
Old Jul 4, 2005 | 06:02 PM
87 XLT's Avatar
87 XLT
Good deal, glad to hear you got it fixed.
Old Jul 4, 2005 | 06:07 PM
pawpaw's Avatar
pawpaw
87XLT you called that one!!!!
Good to hear you got her fixed detour, god feedback, don't you just love those fast, low cost fixes!!!!
I'm rarely that lucky.
Old Jul 4, 2005 | 08:50 PM
87 XLT's Avatar
87 XLT
Thanks pawpaw, as you say it would be nice if they were all as simple as a quick look at a wiring diagram like this one.
