Dead as a rock.
Old Jul 2, 2005 | 06:08 PM
DT 466Man's Avatar
DT 466Man
They turned out smaller on the web site but if you copy them into Paint they are actually full page size.
I have 11 more for your body style if you need them.
There are more than 2 fuseable links. I would get a volt meter and see where the power seems stop.
I'll get you the rest if you need them.
DT
ps.(not bad for a 17 year old huh.)
Old Jul 2, 2005 | 06:11 PM
theangryviking's Avatar
theangryviking
Ill jump the wire, gimme a sec, OK still nuthin. No dome, tail, brake or dash lights.
No even that damn ding, ding, ding thing I so hate.
Old Jul 2, 2005 | 06:14 PM
DT 466Man's Avatar
DT 466Man
Well i sent you a PM
DT
Old Jul 2, 2005 | 06:18 PM
theangryviking
Thanks, we'll head down to NAPA and pick up a better multimeter and start tracing wires....
My chilton manual doesn't have the charts you have...michael@rivetbase.com
Old Jul 2, 2005 | 06:21 PM
theangryviking
opps, I guess I can't email you cause I'm a newbie.
send the charts to michael@-r-i-v-e-t-b-a-s-e-d-o-t-c-o-m-(get it?)
DT 466Man's Avatar
DT 466Man
you have to leave out the (.com/.net) or it won't show the address.
I put this post on another board so mabey some one might show up to help us out..
DT
Old Jul 2, 2005 | 07:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You should only have one wire on the back post of the solenoid. That wire goes to the starter small terminal.
The other wires you have on the rear terminal should be on the front terminal. One is glow plug power, one is alternator, the other is cab power.
With them on the rear terminal you would only get power to the cab and glow plugs while cranking the engine.
Old Jul 2, 2005 | 09:33 PM
theangryviking
So I just replaced the ignition switch on the steering column, it was really sloppy.
Still no power at any position.
Dave, thanks for cuttin in.
I'm no rocket surgeon, but it sure don't seem like I moved anything from either selonoid terminal that wasn't attached to the battery cable(s)...hummmm.
Now, buy back post - you mean toward the rear of the truck right? In the USA?
I'll switch em out...
Thanks,
Vike
Old Jul 2, 2005 | 11:17 PM
94F450SD's Avatar
94F450SD
on the solenoid you will have 2 battery cables,one from the battery on one stud the other goes the starter on the other stud.now you should have a bunch of wires with big loops on them,these go on the stud with the cable from the battery not with the cable that goes to the starter.then you have the little booted wire wich goes on the small stud.the battery cables that goes down to the starter is on the one stud on the solenoid by itself there should not be any other wires on the same stud with it.
Old Jul 3, 2005 | 01:32 AM
PLC7.3's Avatar
PLC7.3
Check all the fuses in the engine comp fuse box, then check all in the cab fuse box.
Old Jul 3, 2005 | 06:56 AM
Dave Sponaugle
Yes the rear of the truck.
Mine has all the wires on the front terminal closest to the battery.
This is one of the main battery power distribution points on these trucks.
The only wire on the rear terminal goes to the starter.
I am only talking about the two big terminals that are bolted on.
Old Jul 3, 2005 | 09:46 AM
theangryviking
I wore a hole in my overalls scratchin my rear all day trying to figure this thing out. And after Dave's post last night, I wandered down to the garage in my PJs with schematics in hand and gosh darnit, I AM indeed the idiot my wife says I am.
(Sheepishly) I have to admit, I switched the 2 red wires to the selinoid when I swapped the battery cable out. Now we're good to go.
Thank you guys very, very huge!
In His grips,
The Angry (but in a very good mood) Viking
Old Jul 3, 2005 | 04:07 PM
  #28
Dave Sponaugle
Glad to help, we don't need any mad and angry vikings.
That would be bad news on the holiday.
Happy ones are much easier to deal with.
Old Jul 3, 2005 | 06:22 PM
  #29
Dave Sponaugle
Don't believe everything that your wife tells you.
It was a very honest mistake.
That is a very valuable part of learning something new.
I bet you will never forget where those wires go for the rest of your life.
So that was a lesson well learned.
And all in all the price was not to high.
Old Jul 4, 2005 | 07:27 AM
  #30
tjc transport's Avatar
tjc transport
i ain't rite
yup, i agree. tell the wife if you were the idiot she claimes you are,
you would be driving a chebby
