Trans lock
Old Jul 2, 2005 | 09:12 AM
86Stepside's Avatar
86Stepside
Trans lock
Went out to the truck yesterday, Started it up and when I tried to put it in gear it would'nt go into any gear. It also wont go in gear with the truck not running. Its a 86 f150 2 wheel drive stepside, w/4spd o/d manual. Is my tranny junk, or is there anything I can Do?
Old Jul 2, 2005 | 09:43 AM
Beast12's Avatar
Beast12
It could be a clutch problem or possibly your shifter is screwed up inside the transmission. I would maybe take the top of the transmission and see what it looks like inside.
Good luck!
-Matt
P.S. Welcome to FTE!
Old Jul 2, 2005 | 09:59 AM
86Stepside's Avatar
86Stepside
I did take the shifter out of the transmission, and looked inside, but I did'nt see anything funny in there.
Old Jul 2, 2005 | 11:45 AM
Mike38's Avatar
Mike38
How is the feel of your clutch pedal? Is it hydraulic or mechanical? You should check your firewall for any flex because that would not enable you to engage the clutch all the way and it won't go into gear while running. It could also be a fault in your master or slave cylinder. Is it not going into gear even if you try to force it? That could be a shift fork problem. I know it sounds like a lot, but you have something new to look at.
Mike
Old Jul 2, 2005 | 12:24 PM
86Stepside's Avatar
86Stepside
thank you Mike, I will check those things you suggested.
Gabe
