E4OD Tranny problems!
Old Jul 2, 2005 | 02:23 AM
destruck's Avatar
destruck
My grandpa drives a '85 F150 with the auto E4OD transmission. Lately it will while driving switch into neutral by itself, and lose power to everything, all he can do then is coast. A mechanic has replaced the sensor 3 times, and still had the same problem.
I did a search, didn't really find anything relating to this, although I just skimmed some threads.
So my question is, could it be the transmission itself? They want to charge $2500 to swap out for a new one, but I would like to make sure this is not solved a different way before forking over that kind of cash. I don't see how a sensor would cause it to shift by itself, so I was thinking the gears are messed up or lose or something, letting it slide or jam into neutral. Please, any insight would help at this point. Thanks in advance.
Old Jul 2, 2005 | 03:35 AM
RR4E's Avatar
RR4E
I'd take it to an actual transmission shop, as opposed to just a general mechanic. A lot of times, the specialty shops are better than the general shops for such a diagnosis. I can't see a sensor being the problem, as the sensors are generally for speed only. This sounds more like a linkage or loose cable problem, or possibly a wiring problem.
Old Jul 2, 2005 | 06:16 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 2, 2005 | 06:53 AM
Beast12's Avatar
Beast12
I agree with RR4E. A transmission shop specialize more in this kind of thing. Good luck!
-Matt
Old Jul 2, 2005 | 01:08 PM
destruck's Avatar
destruck
Well, he took it to the dealer also, but I will tell him to try a tranny shop, see if they can help any more. Thanks guys.
