Air-Filter Replacement (Is There Updated Intervals)??
I thought I read or heard that Ford issued an updated service advisory that this is to frequent and costly and that the filter-minder guage should be used and the filter inspected... but not necessarily replaced uless the filter-minder guage says that it is restricted??
Can anyone point me to the Ford bulletin or webpage?
Thanks,
Jeff
15,000 miles is about right for our trucks; the powerstrokes eat a lot of dirt. The filter-minder? Piece of junk - none of mine have ever worked. The way to know if the filter is dirty is simply to open it up.
Can some one out there look up the TSB and advise what it says.
TSB Bulletin #: 16625
Sequence #: 10002503
Date: 20030201
Please advise what this TSB states... otherwise I can always call my dealer and ask.
Thanks,
Jeff
BTW, I checked out the air, fuel and oil filters we use on our giant multi-million $$ mining equipment. They all use CAT or Donaldson filters. After seeing that I think it is money well spent.
See the following thread from Tim for the link:
https://www.ford-trucks.com/forums/s...d.php?t=388918
Daryl
Date: 20030201
Thanks,
Jeff
Yes I know about the newe section of FTE... that's where I got the info.
All it gives is the bulletin number and that an airfilter change interval update has been advised or given... but that's all.
So I ask again... what is the new interval and what does the TSB say specifically?
This new section of FTE is nice, but it only gives an overview of the issue and no specifics.
Thanks for the assistance.
Jeff
Date: 20030201
Thanks,
Jeff
</td> <td>2003 EXCURSION, SUPER DUTY F SERIES</td></tr></tbody> </table>
ISSUE:
Some 2003 F250-550 Super Duty and Excursion vehicles equipped with a 6.0L Powerstroke engine, may exhibit a difficult to remove or replace air filter assembly during service.
ACTION:
The following procedure has been provided to assist with air filter removal or installation during service.
SERVICE PROCEDURE
Filter Removal
- Release 4 toggle clamps located on top of assembly (Figure 1).
- Lift inlet slightly, enough to disengage the 2 tabs on the bottom of the inlet cover from the 2 windows on bottom of the filter inlet, and push it forward toward front of vehicle as shown in Figure 2 and Figure 3. <table border="0"> <tbody> <tr> <td width="80">NOTE:</td> <td>THE CLEARANCE BETWEEN THE INLET BELL MOUTH AND THE GOR (GRILL OPENING REINFORCEMENT) VARIES BETWEEN VEHICLES. IN THIS STEP, JUST ENOUGH CLEARANCE BETWEEN THE INLET COVER AND THE FILTERS 2 INLET WINDOWS IS NEEDED SO THE FILTER DOES NOT GET HUNG ON THE INLET.</td></tr></tbody></table>
- Separate the outlet cover from the filter by pushing on top of cover as shown in Figure 4. <table border="0"> <tbody> <tr> <td width="80">NOTE:</td> <td>COVER SHOULD BE AT APPROXIMATELY 15 DEGREES FROM FILTER, AND VISIBLE GAP ONLY AT THE TOP, AS THE TABS ARE STILL ENGAGED AT THE BOTTOM.</td></tr></tbody></table>
- Pull outlet cover up enough to disengage the 2 tabs on the outlet cover and the filters 2 windows located at the bottom of the clean side. At this step, the MAFS may contact the degas bottle while pulling the cover up but this should not create a problem. Push cover slightly away from filter and down as in Figure 5.
- Pull filter upward to disengage its 2 legs from grommets (Figure 6). It is easiest to rock the filter forward/aft while pulling it up.
- Use the guide on the filter to align its legs to the grommet during its installation as shown in Figure 7, making sure filter is fully seated on the cradle.
- Attach inlet cover to filter using the 2 clamps on inlet side, making sure that tabs are seated inside the windows (Figure 8).
- This step my require some effort/force to assemble the cover to the filter. Pull cover up, and bring it at an angle to attach the 2 tabs to the 2 windows at the bottom of the clean side as shown in Figure 9 and Figure 10. In the next step, make sure clamps are out of the way and do not interfere with the seal.
- Bring top of cover toward the filter using both hands as shown in Figure 11. You will encounter some resistance but should press firmly. Attach the inboard clamp first while holding pressure on cover, and then attach outboard clamp.
Thanks for the post above about how to change the air-filter... but my question is about the TSB relating to "change intervals".
The TSB "brief summary" says.... "Air filter replacement intervals / Owner guide maintenance supplement update..."
My question is.... what is the update to the intervals as it relates to this TSB????
Thanks,
Jeff
