please help!
Old Jul 1, 2005 | 03:59 PM
bensr's Avatar
bensr
please help!
today i was driving down the road in a 87 f250/350 and had the radio on no ac going and windows down and all of a sudden smoke starts to pour out of the dash i cut the truck off and pull off the road and look for the burnt wire but couldnt find it..got home started to tear apart and found the wire its a black with a green strip wire but we cant find were it goes? does anyone happin to know were this wire would go to or have a site with the wiring? the wire looks like it went to the little plastic peace that pluged into the switch u turn the lights on with.. any help would be nice..this is on a diesel 6.9 motor
Old Jul 1, 2005 | 08:36 PM
Franklin2's Avatar
Franklin2
Look in the lower right corner of this diagram.
http://www.autozone.com/images/cds/g...3d800a3a5b.gif
There is a black/lightgreen that goes from the ignition switch to the wiper module.
If you look at this diagram.
http://www.autozone.com/images/cds/g...3d800a3a5c.gif
You will see in the upper left corner that the lights are fed by a black with a orange stripe.
Old Jul 1, 2005 | 09:07 PM
bensr's Avatar
bensr
That helps some, the wire that fried is a small blk/green strip it goes to where 2 large blk/green strips are connected by a factory junction they all loop off the piglet that goes to the head light switch. I guess i need to drop the steering column case we can't get to where the fried one goes into the large coil of wiring harness wires.
Old Jul 2, 2005 | 11:18 PM
bensr's Avatar
bensr
heres what i got big black wire with green stripe coming out of ignition switch runs together with another big black wire with a green stripe then they go into one small black wire with green stripe then runs into small black box with 6 wires has a red,white, black with green stripe, black with pink stripe, and 2 other colors then they run straight through the black thing and go into the internal windshield wiper washer switch, my question is what could have cause this wire to fry like this??? i found another wire that was burnt to the wire in one part...can i just run a new wire for the black with grren stripe?? or do i need to run new wire for it and buy a new switch that controls the diff setting? the switch went bad about 10 years ago and only had one setting switch...so could that have finally gave out and burnt the hole wire?
Old Jul 3, 2005 | 08:30 PM
Franklin2's Avatar
Franklin2
Well, if you look at the diagram, it sounds like those wire colors do match the wiper system wires. Do the wipers work? And I would also get out under the hood and check the wiring around the wiper motor. And also the wiring where it goes through the firewall. I am surprised the wire smoked, instead of blowing the fusible link over at the passenger side fender/starter relay + post. Maybe someone cut the fusible link out and didn't put it back.
If you are afraid of smoking wires again, and want to test it first, disconnect the battery and put a battery charger on the + cable and the - cable. The charger should have enough oomph to run your accessories, but it has a self-resetting circuit breaker in it if things try to smoke again.
