In my 53 ford running a 390 stock I am looking for ideas on radiators. I just need a radiator to get this moving and about tapped for cash on my rebuild of this truck. Do you have any ideas for the cooling as in junk yard,used or the such. I know I can get a new griffin or such but just dont have the 400 scoots right now. Can you guys give me some ideas on cooling from your own experiences and different applications. Thanks so much . DJ
I'm not sure about the 53-56 trucks and the placement of the inlet and outlets that you would need for a Ford 390. In my 49 F1 with Caddy engine I'm running a 4 core radiator from a mid 70's Dodge truck. I ordered it through the local parts store and I think I paid $125 (couple of years ago)
I did alot of research about radiator sizes and models that they fit at sites like; http://webbase.transpro.com/radcat/ http://www.radiatorexpress.com/default.asp
Most of the radiator numbers cross over, and even if the stores con't carry the model # that you want they will usually order it in at no extra cost. Even if you have to go to a wrecking yard, the two radiator sites listed above can give you an idea of what kind of car to look for as they usually list the radiators with all the dimensions and outlet positions.
If you have the factory radiator can you move the inlets and outlets to where you need them? I bet that would be the least expensive.
That's what I did on my '53. I'm running a 5.0L/302. I had the local rad shop delete the extra hose outlets top and bottom. We also had to change the size of the outlets.
If you've got a good local rad shop and your old rad this may save you a lot of grief fabricating mounts and cutting the front rad baffle.
However, if fabricating is easy for you, and $$ tight, check out those websites offered above and head for the wreckers... it'll be the cheapest but mayube not the prettiest!
jniolon, thats just MEAN! The poor guy said he is at the end of his budget....But it IS a nice radiator. Wish I could afford it....But if I put in in my truck, my truck would make it look bad.....So I better not. LOL
I have a 390 in a 54 and use a truck radiator from 73-79 Ford. Nearly perfectly bolts right in after removing the 2 stock "vertical support angles".
I bought a new Supercooler version from local parts store (Auto Zone) and it works outstanding.
This may not be the cheapest solution but US Radiator advertises in the classic truck mags. I had them build a radiator for me to put in my '55 to replace the stock leaker. It was made to fit just as the original and has 4 rows. You can specify where you want the inlet/outlet and if you want trans cooler inlet/outlet. I don't know what their current prices are like but they do make a great product. I would have no problem running a big block Ford with this radiator but am sticking with the 292 Y block.
I have also had good luck having a new core installed on the original tanks at a local shop and going to a 3 or 4 row core. Not as pricey as a new radiator.
I had a radiator from I think a Mustang. It was really small but worked OK. I went to my buddies at Memory Lane and they had a radiator from a 60 Ford F100 completely rebuilt. It's 3 row. I had to fabricate new brackets on the sides, but the top fits great. I took it out and the gauge barely moves off 160 degrees. Spent my 4th of July weekend installing it, but am very excited on the looks and performance.
