Air intake noise
Old Jul 1, 2005 | 02:20 PM
DBtoter's Avatar
DBtoter
Air intake noise
I have a 99 Ranger 4.0 5 speed auto, 4 door quad cab 4x4 with the off road package which is making a loud whinning noise from the air filter box. It does it when it's warm to hot outside and I have had the AC on. it really gets loud when it is at an idle but the gauge shows the temp in the normal range. I removed the air cleaner lid and the noise is comming from the hose that runs to the MAF sensor and then onto the throttle body. The only mods I have made are a K & N air filter and reprogrammed with the super chips tuner. It seems to run fine but the noise is really bugging me.
Old Jul 1, 2005 | 04:24 PM
l-m tech's Avatar
l-m tech
sounds like you have a resonating idle speed control valve.
Old Jul 1, 2005 | 07:08 PM
Blue Jeff's Avatar
Blue Jeff
DBtoter, I had the same problem, sounded like a train whistle to me. I posted this thread and ended up the IAC valve. I have the similar setup on my Ranger. Take a look at this thread.
<a href="https://www.ford-trucks.com/forums/archive/index.php/t-252534-K%26amp%3BN%20Filter%20Intake%20Humming">K&N Filter Intake Humming</a>
This should help. Let us know.
Old Jul 2, 2005 | 01:56 AM
maticuno's Avatar
maticuno
If it sounds like a foghorn...then it's your IAC valve. A $50 part and about 15 minutes to replace it yourself. Common occurance on the 4.0L.
Old Jul 12, 2005 | 11:16 AM
spottin466's Avatar
spottin466
I have the same noise in a 98 Ranger 4.0. I will try try the fix and let you guys know.
Bill
Old Jul 26, 2005 | 10:15 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
That noise is often referred to as a "moosing" sound!
And I agree, it's probably the Idle Air Control.
Good luck!
