power steering pump leak
Old Jul 26, 2005 | 09:49 PM
griz4718's Avatar
griz4718
What would cause fluid to be forced out the vent hole on the power steering pump (94 ranger w/4.0). The reservoir has not been overfilled.
Old Jul 26, 2005 | 10:45 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Air trapped in the P/s... have you recently replaced the pump? Or turned the wheels left or right with the engine off?
It may bleed itself sitting overnight. I have luck holding the engine at 2500rpm while cranking the wheels stop-to-stop about a dozen times. In extreme cases you can hook up a hand-held mechanical vacuum pump to the reservoir (with an adaptor) and pump 15" of vacuum for 10 minutes.
Good luck!
