Exhaust manifold weld
Old Jul 1, 2005 | 12:32 PM
mr_muldoon's Avatar
mr_muldoon
Hello, I am in need of having a cast iron exhaust manifold welded...need to reattach the downtube(flange).
Is this an easy job at a weld shop, how good will this hold? I am looking to attach a turbo and this should help, the manifold will not need to support the weight of the turbo.
Old Jul 4, 2005 | 05:25 PM
Re-Possessed's Avatar
Re-Possessed
Mr-Muldoon.....hope your 4/july weekend is going good.I have been doing yard work/got a round of golf in and the kids came over kicked my butt on the play station 2. But who cares about all of that. Today I was replacing the exhaust manifold gaskets on my 73-250 for the first time since I have had the truck ( a year give or take) and found the weld that I didnt know was there had failed. Take a look at the pictures on my user page. Your call...... Depending on when you look these pictures up they may or may not be posted yet. It takes a little while so i understand.
Old Jul 18, 2005 | 04:41 PM
53fatfndr's Avatar
53fatfndr
A GOOD welder can do it. It's a tedious process involving alot of prep time to the damaged area along with preheating, stress relieving, proper post-welding cool down and such. A filler metal that has Nickel in it MUST be used, unless it is brazed. If the base is welded with Ni-rod, you should see good results. Find a good shop that knows how to properly weld cast iron and you should be good to go.
Old Jul 18, 2005 | 08:44 PM
kens64's Avatar
kens64
Agreed. I made a passenger dual exhaust manifold for my 292 years ago out of 2 different stockers just by welding the 2 together. Find a good welder and it will hold.
jaymontana
1947 and Older Ford Trucks
Dec 18, 2007 03:03 PM
metalZ
13
Mar 17, 2007 04:56 PM
John7894
Feb 22, 2006 02:25 PM
Todd
Jul 10, 1999 11:23 AM
