Aerostar Ford Aerostar
AC line removal
Old Jul 1, 2005 | 09:29 AM
whynot's Avatar
whynot
AC line removal
I have a line coming from the condenser that has a hole worn in it. How do I remove it to replace it?
Old Jul 1, 2005 | 11:29 AM
aerocolorado's Avatar
aerocolorado
The connections are spring-lock, which require a special tool to disconnect them. The tool is just a circular plastic or metal piece that clips over the line and slides into the spring-lock to hold it apart. The tool is inexpensive and usually sold as a set of four different sizes to accomodate the various sized connections you will encounter in the Ford A/C system. Some of the connections can be buggers to get apart, even with the tool, while others just pop apart easily. Spraying the connection with WD-40 often makes it easier to remove. Don't start with a hard to get to connection for your first attempt. Since you system is down already, pick an easily accessible connection and practice on that a few times to get the "feel" of these connectors. You will also need to pick up some new replacement o-rings. Using the old ones will likely lead to future leak problems. A Haynes or Chiltons repair manual has some good illustrations and information on these connectors but nothing beats hands on practice. Good luck!
Old Jul 1, 2005 | 10:37 PM
whynot's Avatar
whynot
Thank you. I'll give it my best shot. It's the line that comes out of the condenser.
Old Jul 2, 2005 | 06:46 AM
CdnSoldier's Avatar
CdnSoldier
I hope you don't have duel AC. The hoses are unavalible. I went to Ford to get a new one. It was listed a 600$ Cdn, and there is only one left, its in BC, Cdn. I have to make one.
Old Jul 2, 2005 | 08:09 AM
whynot's Avatar
whynot
No, I have only the basic one. I just have to get some time to get at it. Now's not so bad the heat wave's let up.
Old Jul 5, 2005 | 01:02 AM
Bear River's Avatar
Bear River
Former ******
There are companies that make up and repair most hoses. There are seven in the salt lake city area. I would imagine that you can find them in the hydraulic section. If you are having difficulty, ask the hydraulic shops where they get their hoses.
Old Jul 5, 2005 | 03:27 PM
CdnSoldier's Avatar
CdnSoldier
Here's a link to parts. http://www.rockauto.com/
Old Jul 5, 2005 | 04:08 PM
whynot's Avatar
whynot
Gracias me amigo
chesster51
Aug 1, 2016 08:30 PM
speedracer1000
Mar 4, 2013 01:36 PM
blowin smoke
2004 - 2008 F150
Jun 18, 2011 11:47 AM
octaneforce
Apr 6, 2011 03:26 PM
1982fordf100
Jan 25, 2004 01:49 AM
