Error Codes
Old Jun 30, 2005 | 07:09 PM
Judson4.9L's Avatar
Judson4.9L
Error Codes
I got codes 87 which is fuel pump primary circuit failure and the other is 14, two or more successive erratic profile ignition pickup (PIP) pulses occured. Can anyone help me with either or both of these problems. It misses very bad usually only when I first crank it up. The gas mileage is also very bad and would love to fix this problem especially when gas prices are so high.
Old Jun 30, 2005 | 09:40 PM
OrdoDraconis's Avatar
OrdoDraconis
THE IGNITION PICK UP IS IN THE DISTRIBUTOR MARK EVERYTHING BEFORE REPLACEING IT TIMING AND ALL, AS FAR AS FUEL PUMP CHECK THE RELAY AND VOLTAGE WITH A MULTIMETER GRAB YOU TRUSTY HAYNES MANUAL AND IT SHOULD HAVE THE CORRECT VOLTAGE IN IT.
