Sponsored by: Innova
HELP!!!!! How to install distribution block!!?!?!?!?
Old Jun 30, 2005 | 04:53 PM
moose94's Avatar
moose94
Hey guys. I need help quick. I don't know how to install a dist. block from my cap. If anyone knows please help me out. Thanks!
Old Jun 30, 2005 | 09:13 PM
BlueMagRT's Avatar
BlueMagRT
Run wire from battery to cap (don't hook it up to the battery), take the wire that comes off the otherside of the cap and put it into distribution block. Now wire your amps from the other parts of the distribution block.
It is simple most blocks go from one 4ga in to 2 or 3 8ga out. you really can't hook it up wrong because the block isn't grounded and the power flows across the entire block.
if the distribution block is fused then make sure you have the correct fuses on the correct output wires and your done.
Old Jul 1, 2005 | 12:14 PM
moose94's Avatar
moose94
Are you sure this is the right way because I was told differently last night. I have 2 (4) gauge wires coming from my battery into the block that splits it into 4 and from there 2 go to the cap and 2 go to the amps. Middle 2 to the amps, and outer 2, (postive and negative) go to their respective posts on the cap. Is this right?
This is what the stinger box had written on the back.
Old Jul 1, 2005 | 04:40 PM
brianas's Avatar
brianas
that is fine -- as long as you are using only 1 distro block for
all those power wires
generally-
keep your capacitors as close in powerline as possible to the amp
also if possible
use a common ground
Big Hurt
Jan 28, 2016 01:18 PM
L121andrew24
Jan 7, 2016 05:43 PM
loveless41908
Jun 1, 2015 10:49 PM
Johnny L
13
Apr 23, 2013 06:07 PM
jsalty
Sep 13, 2009 07:44 PM
