Exhaust Leak
Old Jan 16, 2003 | 09:45 PM
Racerdave's Avatar
Racerdave
Exhaust Leak
What are the symtoms of an exhaust leak at the Exhaust manifold? Because I think I may have one and it may be affecting the operation of my truck... and how can I check and see if I do?
Old Jan 16, 2003 | 09:48 PM
Mil1ion's Avatar
Mil1ion
Exhaust Leak
It usually starts as exhaust pop,which sounds just like lifter tick.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 17, 2003 | 12:16 AM
benwantland's Avatar
benwantland
Exhaust Leak
>lifter tick.
>Dennis
Except if it's the exhaust manifold, you will hear it mainly when it is under load, whereas a lifter tick is most evident at idle.
Old Jan 17, 2003 | 03:51 AM
Racerdave's Avatar
Racerdave
Exhaust Leak
Does it sound like a nock? Because I think I have a leak and when its idleing it goes nock nock nock nock... and on and on, and if I rev it up a little it gets worse untill its really reving and then it stops nocking.
Old Jan 17, 2003 | 09:37 AM
beartracks's Avatar
beartracks
Exhaust Leak
Do you have a cross over to single exhuast? Is so is there a valve in there to force exhaust through the intake for warm up? I've seen the spring in these go soft and make a heck of a knocking sound.
Old Jan 17, 2003 | 12:48 PM
tw's Avatar
tw
Exhaust Leak
Old Jan 17, 2003 | 01:00 PM
vettman's Avatar
vettman
Post Exhaust Leak
I've had great luck locating exhaust manifold leaks by simply running my finger around the perimeter of each port where the casket contacts the manifold. You must be careful to avoid contact, but you can do this without getting burned. If there's a leak you'll feel the "puff" of exhaust gas as it escapes around the gasket. Best to do this before engine warms up completely, and while it's at fast idle.
Old Jan 17, 2003 | 01:22 PM
ford_nut's Avatar
ford_nut
Exhaust Leak
A trick that works for me is to run the truck at night in the dark. If it is an exhaust leak at the head/manifold junction, you will see the fire from combustion ever so slightly. I would suggest that you fix such a leak immediately because I had a couple exhaust valves burn from having leaks like that
GOOD LUCK
regards
Ben
