won't idle
Old Jun 29, 2005 | 07:58 PM
Chillza's Avatar
Chillza
won't idle
I just bought a used ford excursion 2000. After starting it up yesterday, it immediately died on me. It starts every time, but won't idle. What could be the problem?
Old Jun 29, 2005 | 08:07 PM
ford390gashog's Avatar
ford390gashog
the iac valve. a new one cost about 40.00 check the sticky in the 5.4 and 4.6 engine forum
Old Aug 27, 2005 | 05:06 PM
grabe's Avatar
grabe
Resolution
The Air Control value on the 6.8L engines get dirty and stick.
Mounted in the top/back of engine. Remove simply with small bolts.
Usually can clean by spraying with carb or brake cleaner. Known problem because Ford dealers usually have plenty of new ones in stock.
Once cleaned, pop back in and the V-10 will idle like a charm.
Some place on Forum is a picture showning exact location.
Not hard to find, just hard to reach.
Need to climb on the bumper to reach the top/back of motor.
