Which Oil to Use
Old Jun 10, 1999 | 02:29 PM
RogerW's Avatar
RogerW
Which Oil to Use
I have an 87 F150, 203 with 110,000 miles on it, was thinking about switching from 10W30 to perhaps 30? I live in the hot new mexico desert.
Old Jun 10, 1999 | 02:43 PM
RogerW's Avatar
RogerW
Which Oil to Use
Oops, that's a 302 engine.
Old Jun 10, 1999 | 10:35 PM
Mulletwagon's Avatar
Mulletwagon
Which Oil to Use
No problem, you can use 30W in any warm climate. Should help oil pressure on an Autumn engine.
Did you determine the cause of your previous engine flame out problem ????
Old Jun 11, 1999 | 03:52 PM
RogerW's Avatar
RogerW
Which Oil to Use
Well, I thought I had the flameout problem solved, I had the pickup coil/stator replaced about two weeks ago, but today it stalled on me for a moment, till I pulled over. When I tried to restart, it fired right back up. Not sure what happened, will see it it recurs. Any suggestions on what to check next if I get a stall or no run condition again?
Old Jun 11, 1999 | 03:58 PM
RogerW's Avatar
RogerW
Which Oil to Use
Was the send all replies by email feature taken off for some reason?
Old Jun 12, 1999 | 06:34 PM
Mulletwagon
Which Oil to Use
Check for a spark at the plug wires. If you have a good spark but no fire, check the computer ground wire. It is potted into the battery negative cable through a connector. Can't miss it, it is the small wire that goes into the battery cable lug. That was my problem when I had the exact same symptoms on my 88 Bronco.
Old Jun 14, 1999 | 08:33 AM
RogerW's Avatar
RogerW
Which Oil to Use
That was my thought also, I was thinking about replacing my plugs and wires..Not sure when the last plug change was. I'm gonna remove a plug and look at it. Do you think replacing the spark plug wires is a good idea? I was just thinking about taking it to a shop for a tuneup...no idea if the truck ever had one done.
Old Jun 14, 1999 | 12:06 PM
RogerW's Avatar
RogerW
Which Oil to Use
Where can i find this connector, i do see some wires attached to the negative battery cable at the terminal, is this it? I don't see any connector.
Old Jun 14, 1999 | 04:10 PM
Mulletwagon
Which Oil to Use
You should have two small wires clenched into the negative battery lug along with the heavy cable that attaches to the engine in the viscinity of the starter. Follow these two wires for about a foot or less and right before they go into the radiator support there should be a two prong connector. Even if it looks good, disconnect and investigate. Incidentally, one wire is the computer ground and the other is ground for the ABS. Typically, the thin brass female portion of the connector tends to erode and break down intermittently.
Old Jun 14, 1999 | 06:05 PM
H8monday's Avatar
H8monday
Which Oil to Use
Old Jul 29, 2006 | 01:49 PM
DEALLYION's Avatar
DEALLYION
Question no fire to the sparkplug
I Replace The Timing Chain On 1980 Ford F-100 302 Engine. When I Tried To Start It I Had No Fire To The Spark Plug So I Replace The Modulator And Pickup Coid. Its Still Not Getting Any Fire To The Plug What Did I Do Wrong.
Old Jul 29, 2006 | 02:27 PM
DEALLYION's Avatar
DEALLYION
